center bearing
    center bearing
    does the center bearing go on a certain way which side goes on the inner shaft? do yo ubut a lot of moly grease? what does it mean by preloading it? the bearing looks different on each side one side its aligned with the rubber the other side is like 1/8 lip with rubber teeth. which side goes where. any help would be great.
    somebody?
      Ok IF you are under the car looking towards the rear of the car the Front of the bearing goes towards the rear. On the bushing there is the inner bearing then there is a flexible rubber part that connects the bearing to the outer support bracket. The rubber part is connected to the Front of the busing so the rubber section need to place the rear of the vehicle when installed. Now Preload means.... when you install the driveshaft loosely botl on the bracket then push the bracket towards the rear of the car a couple cm, then tighten the bolts while holding it in the this Preloaded posistion. Hope this helps.
      85 325e 2.7 ITB'd stroker
