hey guys what do the different colors of the ECU stickers mean? thanks for your help!
Different colors of ECU's? what do they mean?
Originally posted by whiltebeitelHas anyone told you your car sounds like secks? Big, manly, hairy sex, that is. None of that wussy romantic "making love" crap, either.Comment
There's a red 153-154?? something for an ix, i think theres' a list in the Bently just can't find it, again is it you can't read the #'s, fitting, What are you trying to do?????? the older ones only have 35 pins 1.1, the newer ones have 55 3 rows of pins, 1.3, thinner red ones are E34+ obdI. A blue IX, i wonder if the IX ECU's have a torqueier?? map for the 4 wh drive, never had one to play withComment
The reason im asking is because i recently did an engine swap and it came with a red label ECU. i have a 1990 325i convertible and it has a yellow ECU so i was wondering what the difference between them was. i dont know what you mean by look at the numbers on them...There's a red 153-154?? something for an ix, i think theres' a list in the Bently just can't find it, again is it you can't read the #'s, fitting, What are you trying to do?????? the older ones only have 35 pins 1.1, the newer ones have 55 3 rows of pins, 1.3, thinner red ones are E34+ obdI. A blue IX, i wonder if the IX ECU's have a torqueier?? map for the 4 wh drive, never had one to play withsigpic
There a 2X3 colored sticker on the ECU with these #'s 0 261 200 + one of these last three #'s 150,154, 173, 380 + the ones mentioned above off the 325I/IX. yellow vert ECU is the 380. Pictures might help, as long as its not green or pink label with 021-027 and a 325I M20 they both should work. The 173 one has the best stock set up.Comment
