The PO of my car had disconnected the reverse lights because they were blowing a fuse. Thanks to this forum, I went underneath the car and discovered that the reverse switch wiring was touching the driveshaft, worn, and shorting the fuse. I placed black tape over the wire to repair the worn spot. I saw from other posts that people zip tied the wire out of the way... so it didn't continue to rub on the driveshaft.
I zip tied my reverse wire loosely to the shift rod that extends to the transmission. My question: is that an okay spot to zip tie the wire? I didn't see any other good place to zip tie it to.
Thanks.
-Marc
Thanks.
-Marc
