[B]HELP IN SACTO[/B]: Stephen is broken down
  • Stephen
    Шлем ишака
    • 10774
    who just tried to call me? cell reception here is terrible
    • Jean
      • 18228
      I did, left you a VM. Whats up?
      • Stephen
        Шлем ишака
        • 10774
        ill call you from my friends house phone soon. The cars cranking but wont fire. havent tested for spark yet. it came on for a second earlier then died right after
        • AbsorbantNut
          Non faccio funzionare questa merda
          • Jun 2010
          • 2491
          Possibly fuseible link in the rear pos. battery cable. Thats what happened to me. It would crank and I wouldnt get fuel or spark.
          '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
          • Jean
            • 18228
            So, if it was an ETA and it cranks....can it still be a fusable link?! I never had one of those.... and it sounds like his car is still a dual pump car.
            Stephen is going to check for spark next and then for fuel... to get the easy things out of the way.
            • pureaudio
              • 1123
              Sucks your not anywhere near Redding, I have an entire parts car you could snag whatever you want off of.
              • TexasTerp
                • Jan 2009
                • 3541
                If it doesn't turn out to be either of the Fuel pumps then it is most likely the CPS. Just watched a nearly identical situation happen at GutenFest last month with my buddy Jeff's car (aka e30_325es).
                stephenbrody.com
                • ak-
                  • 12422
                  Your car won't crank without a working cps. A weak one, maybe?
                  GL >:l
                  1991 325iS turbo
                  • Stephen
                    Шлем ишака
                    • 10774
                    swapped to a spare 153 ecu and it fired up, but died from the shock of slamming the hood closed. so i found a slightly lose connection on the ignition coil. seems more solid now, but i did kill it once after putting back to 173. not sure if the problem is solved with the tighetened ignition coil AND the 153, or just luck
                    • b*saint
                      • 3794
                      Damn, I just gas'd up my jet, with two main fuses and a spare DME.
                      Ma che cazzo state dicendo? :|
                      • AbsorbantNut
                        • Jun 2010
                        • 2491
                        I dont know about the ETA part, but mine would still crank when the fusable link was bad
                        • Stephen
                          Шлем ишака
                          • 10774
                          I found a loose connection off the harness to the firewall whereit meets battery/power wires. Think that was the culprit
                          • 416stroker
                            • May 2008
                            • 2448
                            Where are you now?
                            Is it driving?
                            84 318I Delphin RIP
                            87 325IS delphin 24v Sold
                            89 325 Alpineweiss
                            • Stephen
                              Шлем ишака
                              • 10774
                              i just took it for a test drive, no hiccups. need to find somewhere to bottom out or something so i make sure theres no more loose conecctions. im in lincoln ca
                              • BarryM6
                                • Jun 2006
                                • 39
                                you good im around the corner..
                                Barry
