So I finally did my clutch I'n my 1987 eta. I decided to go with a 325i flywheel and stage one clutchmasters clutch kit.
So how did I put a 325i flywheel I'n my eta. Easy I just welded the reforence pin on to the i flywheel. Didn't take long to find the right spot to weld the pin.
Any way I thought it would be a good idea to let you eta guys know that it can be done fairly easy and the 325i flywheel is about 8 lbs lighter then are dule mass flywheels that cant be resurfaced.
You will need 325i flywheel bolts, 325i clutch kit, and I would recommend 323 throw out bearing.
The car realy feels great. I'm not sure if any of it has to do with the lighter flywheel or if it's just having a new clutch.
