So I searched the forums and only found threads on tail light leaks. Noticed a moldy smell in the trunk and water keeps filling underneath the battery. Where is this damn leak coming from? Is it the lid?
Damn leaky trunk.
Check sunroof drains, taillight gaskets, trunk seal, antenna seal, and those little tabs that hold the c pillar trim in behind the window, those are a direct hole into the trunk.1985 M10b18. 70maybewhpoffury. Over engineered S50b30 murica BBQ swap in progress.
Originally posted by DEV0 E30You'd chugg this butt. I know you would. Ain't gotta' lie to kick it brostantinople. -
It's probably the sunroof drain. There's one on each corner of the sunroof and one empties right where you have water. Use an air compressor and blow the line out from the sunroof and that should do it. While you're up there, do the other three too - if one is clogged the others probably are too.Comment
Be sure to do this GENTLY, or you might have a larger leak. I would start with a glass of water and pour it in each drain, then see if you can catch the leak.It's probably the sunroof drain. There's one on each corner of the sunroof and one empties right where you have water. Use an air compressor and blow the line out from the sunroof and that should do it. While you're up there, do the other three too - if one is clogged the others probably are too.1985 M10b18. 70maybewhpoffury. Over engineered S50b30 murica BBQ swap in progress.
Originally posted by DEV0 E30You'd chugg this butt. I know you would. Ain't gotta' lie to kick it brostantinople.Comment
We fought the wet trunk for years... new trunk seal, new antenna seals, new tailight gaskets, both on the older and newer models.... and even siliconed the tailights.. Still had water getting in...
One car had a bad weld where the trunk hinge attaches under the rear window, if you open the trunk and look in front of the trunk seal, you will see a couple of divots, those are the spot welds, one of ours cracked.
thought we had found the problem, but no.... water still got in....
The problem all along was the gasket around the vent where the sunroof drains drop out at... it is part #9 in this penske diagram...
http://www.penskeparts.com/DiagramsR...iagram=51_0836
One of our we put new gaskets on, the other, we just ran a bead of silicone around it, let it tack up and then reinstalled the vent.
Good luck.Comment
Mine turned out to be the left taillight. I checked the antenna grommet, but it was good, then I poured water down the left side trunk drain rail, and soon water started leaking into the well where the jack sits. I took the light out and cleaned the gasket, re-installed it with silicone sealant, but it still leaks. I've ordered a new gasket which should fix the leak.Comment
My leak was trunk gasket and taillight gaskets
One of the best threads you will ever read
http://www.r3vlimited.com/board/showthread.php?t=221813
Nice trailer of my e30
http://www.youtube.com/watch?v=TTjtG...e_gdata_player
If i sold you something please leave feedback here
http://www.r3vlimited.com/board/showthread.php?t=217142Comment
My taillights certainly have leak in them even though I have new seals in them now..... May need to silicone them shut :(
My E30 332iS Build Photo Album :) Click below!!!!!!!!!!
http://s637.photobucket.com/user/mil...2%20SWAP/story
If you have bought or sold parts from me please visit my Transaction Feedback Thread!!
http://www.r3vlimited.com/board/show...10#post3791810Comment
1991 325i Calypso Coupe
Like Grandfather, Like Father, Like Son
BMW
BMW
