I changed fuel pump and car did not turn on. I took volt meter and checked there is no power at the pump. There was power before I changed fuel pump. What could be wrong? I can see wire is going to the trunk. Do you guys have fuel pump wiring diagram? Anyone got solution?
No power at fuel pump
there's not always power to the fuel pump unless the engine is turning over
You can jump the terminals on the fuel pump relay to check and see if the wiring is OK- just connect the 2 larger wires out of the 4, I *think* one is red and the other is purple/green. Jumping them will send power to the fuel pump whether the key is on or off, so don't do it too long.
Why did you change the fuel pump????Comment
Car is been sitting in garage for 4 years and won't start. So I put little gas in air intake and car wanted to start. Car was not getting gas so I looked if fuel pump is getting power. It was then I took out fuel pump and it was shot. Also had to change injector since they were clogged. After doing all that all the sudden no power at fuel pump.there's not always power to the fuel pump unless the engine is turning over
Why did you change the fuel pump????sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.Comment
