i'm in the market of getting a 4 door 325 and the weak rocker arm bother me a bit. i'm leaning toward the 325e since its a better econ car. does the two car have the same rocker arm? since the 325e have a lower redline would that make the 325e less likely to break a rocker arm?
325e, 325i rocker arm the same?
Tags: None
The are the same, and Guten parts has the IE HD rockers to replace the OEM ones.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8is -
What matters most is how often the valves were adjusted. I would rather buy a used set from an 'i' knowing they were regularly adjusted than a set from an e where the owner can't tell me when they were adjusted. IF there is a difference in the likelihood of snapping a rocker between the two I would say its pretty small.-AlexComment
