I'm thinking about selling, but haven't the slightest what it's worth. I've owned it a couple years and have done a ton of maintenance and some performance mods.
Car has a 5 speed manual, limited slip diff, sport cardinal red leather interior, all the good 'is' stuff. The mileage is currently at 180,800. Runs great, never a question about reliability. I've gone through most of the engine and a lot of the suspension as you can see from the list of items replaced below.
The bad:
-Pass window doesnt roll down
-a/c doesnt work
-A few dings/scratches (worst is a slight wave in drivers rear quarter)
-some small surface rust on left door bottom
-dash is cracked
-leaking oil pan gasket (have part but haven't installed)
Items replaced with brand new parts since I bought it (the good):
180000 miles:
Fuel filter
Plugs
Fuel pump relay
Shocks
Struts
Air cleaner
Water pump
Windshield (used but not cracked)
178000 miles:
Lowering springs- Eibach pro kit
Drop hats
Wheels- 15x8
Tires- 205 falken azenis (super sticky)
Valve seals
Cap
Rotor
Ambient temp sensor
Bump stops
Shift bushings
Valve adjustment
Intake gaskets
Exhaust gaskets
Valve seals
Head gasket
Timing belt/tensioner
Water pump gasket
Crankshaft seal
Camshaft seal
Pinion bearings
Rear wheel bearings
Subframe bushings
Diff fluid
Valve cover gasket
Fuel check valve
Fuel pressure regulator
Front rotors
Rear pads
Drive shaft
Center bearing
Guibo
Accessory belts
Crap photos, but they should give you an idea.
The bad:
-a/c doesnt work
-dash is cracked
180000 miles:
Fuel filter
Plugs
Fuel pump relay
Shocks
Struts
Air cleaner
Water pump
178000 miles:
Drop hats
Wheels- 15x8
Valve seals
Cap
Rotor
Ambient temp sensor
Bump stops
Shift bushings
Valve adjustment
Intake gaskets
Exhaust gaskets
Valve seals
Head gasket
Water pump gasket
Crankshaft seal
Camshaft seal
Pinion bearings
Rear wheel bearings
Subframe bushings
Diff fluid
Valve cover gasket
Fuel check valve
Front rotors
Rear pads
Drive shaft
Center bearing
Guibo
Accessory belts
