110 Octane
  • ToplessE30
    • 4791
    110 Octane
    I stopped at a "Pumpers" Gas station on the way back from Charlotte this past weekend and they had a 110 octane race fuel. It said for off-road use only. Just wondering, what would it do if it were put into a vehicle like ours? I'm sure some adjustments would need to be made before fueling. Seemed pretty interesting.
    Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
  • Hatchman
    • Mar 2005
    • 1425
    price per gallon?
    • Jordan
      • 12912
      It won't do anything to a car like ours.
      No knock sensors, and no adaptivity to take advantage of it.
      Newer cars are able to detect the fuel grade, and adjust spark and fuel timing for optimum output. Turbo cars will see a good amount of increase with such fuel.
      But again, putting it in your m20 will make no difference.
      https://mtechniqueabs.com/
      • 87 325iS
        • Jun 2004
        • 277
        110 octane is leaded.
        Amber Fire Pearlcoat 2000 Dodge Dakota R/T
        Schwarz 1991 BMW 535i [Daily Driver]
        Dark Currant Pearl 1996 Acura Integra GS-R [For Sale]
        Orientblau Metallic 1994 BMW 740i [Sold]
        Alpinweiss 1987 BMW 325iS [Junked]
        • permit
          • Mar 2005
          • 3363
          Wait, my post made no sense! Go me.
          • AdironRider
            • Dec 2004
            • 3491
            Its 4.89 a few towns over by the dragway up here in NH
            Back to my roots
            • 87 325iS
              • Jun 2004
              • 277
              The highest octane unleaded gas is 103.
              • Rob
                • 8166
                What jordan said, for the most part.
                BEERTECH
                • Charlie
                  kid tested, administrator approved
                  • 6686
                  Re: 110 Octane
                  It would thrash your O2 sensor and clog your cat, other than that, not much on a standard m20 motor.
                  I've run the 100 octane unleaded stuff occasionally at the track on hot days, in 95+ degree weather, it definetly takes out some of the pinging.
                  -Charlie
                  Swing wild, brake later, don't apologize.
                  '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                  FYYFF
                  • herragge
                    • 361
                    yeah the high octane stuff with lead in it increases the octane rating but in turn negates the effect of the catalytic converter so you'll get more CO emissions and NOX. They aren't great for the o2 sensors either as the particles of lead will coat them and prevent them from working efficiently.
                    But that isn't new to many people. ;)
                    • M42Technik
                      • 9781
                      Found 98 at a gas station in Northeastern Maryland at the tip of the Chesapeake, apparently near a drag strip.
                      $6.90 a gallon...
                      Reminiscing...
                      • EtaSport
                        • 2853
                        Our local sheetz 3 miles from the drit track sold 100 octane for about two weeks. 5.50 a gallon. Of course I had no interest, but one of my turbo friends was making use of it. Too bad he was stock and only boosting 10psi. We have another station that sells 116 cam2 for around 4.75. I ran it in my snowmobile once when I used to race.
                        Lower fuel octane will burn cleaner, although it will burn hotter and cause the pinging. You should only run enough octane to eliminate any valve ping, unless of course, turbo, high compression or towing purposes. I'm happy still running 87 in the hybrid.
                        Old and improved:
                        • ToplessE30
                          • 4791
                          Price was $4.59 or so. Yeah, kinda rediculous, just the first time I've ever seen it on public streets.
                          • Ryan Stewart
                            I Love Miatas
                            • 8978
                            octane is a rating of resistance to ignition so putting it in your engine would actually make it run a lot less efficient along with all the problems noted by everyone else.
                            Its only really useful if you are running an incredibly high compression or boost where the risk of detonation is high. Like Charlie said it can be useful in small amounts in certain situations.
                            I was getting a bit of knocking on the S50 on 105 days on the track so I mixed in about 1.4 tank of 100 low-lead to just bring up my 91 a bit. A little bit of lead wont hurt, in fact it is there to protect the valves. Its just a lot building up that ruins sensors and cats.
                            Im now E30less.
