Need quick help with cluster
  • jaydeep
    • Jun 2011
    • 208
    I just replaced si board batteries. Putting everything back and need to know where three wires goes? Middle wire goes in to green plug but I don't know if its going in the middle, left, right
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • Vefu
    • May 2011
    • 57
    Blue goes into the blue slot. And the middle wire goes into the top green slot, which I think would be the left in your picture. I have no idea where that third wire goes, when I took out my instrument cluster I didn't even have that wire.
    • jaydeep
      • Jun 2011
      • 208
      Does it matter where I plug that wire in green connector? Do you know what is that for?
      • Vefu
        • May 2011
        • 57
        Yeah it matters, the middle wire has to go into the top green slot. Someone correct me if i'm wrong but I believe that the wire has to do with the cruise control, i'm not 100% on that though.
        • accident
          • 7303
          wire that goes into green plug is indeed for cruise control. though my understanding is that it doesn't matter which of the 3 it goes into, and that it all gives off the same signal. the light bulb wire is CEL if I recall correctly, but it goes into the circular hole with the ribs in it on the far left side of the cluster. other bulb goes into the circular hole on the far right and should be ABS.
          Moral of this story?
