Suspension Bushes Question
    Hi Guys
    I am going to start my suspension upgrade I already have billie sports and H&R sport springs. I am going to place an order for AKG bushes and have two questions.
    1. Should I get the 9mm or 12mm of set Subframe bushes?
    2. What is better the standard or offset CAB's?
    Cheers Guys
    offset CAB's such as IE's m3 CAB's gives the front tires more camber, and if im not mistaken they are stronger/ stiffer. better for spirited driving.
    hope that helps
      Sweet sounds like the way to go now just need an answer on the sub frame bushes
        hope that helps
        more caster, not camber
          no change in static camber, but more caster will cause more dynamic camber.
            So no body can answer the subframe bush question. Oh well ill go for the 12mm that way I can get the offset diff bush as well.
