Hi, ive noticed that when i turn on the ac, i dont hear the aux fan kick loud so i suspected that the resistor was bad, (changed two years ago). So i proceed to remove it and jumper all three wires together. That worked great, the fan turns on high with the ac as it used to do. Now my question is: is it harmful to leave the wires jumpered wiith no resistor? Or can i leave it jumpered?
Auxiliary fan resistor question
One of the best threads you will ever read
http://www.r3vlimited.com/board/showthread.php?t=221813
Nice trailer of my e30
http://www.youtube.com/watch?v=TTjtG...e_gdata_player
If i sold you something please leave feedback here
http://www.r3vlimited.com/board/showthread.php?t=217142Tags: None
the wires may get to hot and burn.
But I have jumped the switch before when my fan clutch died on a road trip. It ran no stop for several hourssigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
The resistor is used to get the fan to run on the low setting. Connecting all three might not be the best of ideas.My previous build (currently E30-less)
http://www.r3vlimited.com/board/showthread.php?t=170390
A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
Originally posted by MR E30 325is View PostThe resistor is used to get the fan to run on the low setting. Connecting all three might not be the best of ideas.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
I won't recommend it by any means.
But My A/C Worked great all summer........
I also use my A/C to cool down my car when sitting still for too long.......
I also use my A/C to blow cold air up the womans skirt when she's sleeping and not looking............
(And my resistor has been broken since the day I bought the car)
(And I didn't wire all three together)
Ok, let me get this straight, the resistor is used to get the fan turn on in the low speed?
Two days ago, when i turned On the ac right upon turning the car cool in the morning, the aux fan used to kick on high. All of a sudden it just didnt want to kick at all, the fuse was fucked so i changed it but the fan didnt want to kick on high, thats where i proceed to jumper the wires together and it worked as before.
There is two red wires and one black, my previous resistor had the two red wires on one end and the black on the other, is that how it was supposed to be? Can someone check for me please?
i have the same problem with my aux fan..its your sensor plug, MOST LIKELY
I replaced my resistor a couple weeks ago and put in a new one. My fan used to never work and that got it running.
now the problem is the fan just ALWAYS runs on low. i swapped one from the junk yard and that one didnt work at all. try the sensor plug. let me know if it worksm20 is plenty. im simply a drifter.
build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
Originally posted by ROLLingKING View Posti have the same problem with my aux fan..its your sensor plug, MOST LIKELY
the system is designed to turn the fan on low speed (thru the resistor) any time the AC is switched on(activates low fan relay K1 in fuse box). or thru the cooling fan switch in the upper right of radiator with temp above 196F activates low speed fan relay K1,above 210F activates high speed fan relay K6.
the black wire is power supply to resistor from K1 (low speed),one red wire is power supply thru K6(high speed )spliced to the second red wire that runs to the motor itself . the brown wire is ground to motor.so by tying all together your backfeeding voltage up to K1 relay when fan is on high speed which wont hurt anything .
question is why is your fan on high with a cold engine and AC ,has relay/switch been jumpered/bypassed?Angus
88 E30M3 X2
89 325IX
92 R100GS/PD
Originally posted by spdracrm3 View Postthe system is designed to turn the fan on low speed (thru the resistor) any time the AC is switched on(activates low fan relay K1 in fuse box). or thru the cooling fan switch in the upper right of radiator with temp above 196F activates low speed fan relay K1,above 210F activates high speed fan relay K6.
1- it didnt turn on with the switch in the on position.
2- it turned on on high speed with the ac on but car cold
3- i think iirc with the ac off it did turn on low and high speeds as it should.
The question here is that why did it used to turn on high speed with the ac on but car cold and all of a sudden everything corrected itself by itself?
Personally i prefer the high speed at all times with ac on, it cools much better on stop and go traffic.
**One more thing, did i have the wires correctly on the resistor? The reds to one end and the black to the other?
You could bypass the resistor like the guys explain above by wiring the red and black wires together and grounding the brown wire. The fan will run on high at anytime it's activated. If that's what happens, then you've narrowed things down to the resistor. Or just keep it the way it is bypassed.
Some mentioned wiring all three together, but I don't know if that's an effective ground. Maybe someone can explain.
