Quick question....
  • grahamsy2k
    • 400
    Quick question....
    Will an Mtech1 steering wheel fit my 1991 318is?
    All just means to an end.
  • EndreM
    • Jul 2009
    • 513
    Not if you put it on backwards.
    '91 E30 316i
    '97 Rover Mini 1275
    • Dean
      • 231
      If it has the correct boss. It should with no issues. Does your 318iS have an airbag wheel in it? If so you'll need a small carbon connector to get the horn to work as you disconnect that with the airbag part. If you have a wheel on there with no airbag, it should fit no issues as said.
      Originally posted by Deltron Dirty30
      Dean, has anyone told you that youre a spitting image of English singer-songwriter and musician, james blunt?
      • Dean
        • 231
        Originally posted by endrem
        not if you put it on backwards.
        rofl
        • F34R
          sLaughter
          • 12376
          Depends, there is MT1 for e24/e28 models. Remove the center BMW coin and look in the groove for model marking. OR send it to me in the mail, I would be happy to tell you ;)
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • Dean
            • 231
            I made this very mistake years ago buying my MTech2 wheel, it came from an E34 M5 and although it looked awesome it didn't fit my E36 at the time! Thats what I meant check the boss. Good luck
            • grahamsy2k
              • 400
              I dont have an airbag.
              and the problem is that the hole in the steering wheel is to small.
              • Dean
                • 231
                It won't fit then lol keep searching!!!
                • grahamsy2k
                  • 400
                  but I want to know why it won't fit.
                  • Dean
                    • 231
                    Its due to the splines that the wheel slide into being different sizes. I think you should be able to get an adapter if you really want it to fit, but when you can get an E30 MTech 1 wheel cheap enough is it worth it? Give up on the idea, sell it and buy an E30 one.
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      It wasn't made for that steering column.
                      • grahamsy2k
                        • 400
                        How will I know if its an E30 one, cause I though this one was right one but I guess not.
