Custom 2002 Sub Frame for Medium Case e30 Diffs!
  • deutschman
    • May 2008
    • 5958
    For those of you building a built and/or turbo m20 monster 2002 this is for you and all the power you will have!!!
    Just found this on the 2002 FAQ. I want one so bad. Maybe next year.
    Just thought I would share. I had nothing to do with anything relating to these parts. Just thought they are sick.
    http://www.bmw2002faq.com/component/...view,/start,0/
    Kit #1
    New rear subframe, delivered in bare steel - $825.00
    New rear subframe, delivered as powder coated - $900
    Kit #2
    New rear subframe (bare steel) with NEW 4340 heat treated
    half-shafts (no CV joints). One side is splined for E30 CV,
    the other side is splined for 2002 CV - $1200
    New rear subframe (powder coated) with NEW 4340 heat treated
    the other side is splined for 2002 CV - $1265
    The prics DO NOT include shipping/delivery charges.
  • glucklich21
    • 1912
    Hmm I would like that plate he mounted the cover to.
    Cool stuff otherwise.
    • SkiFree
      • Jun 2011
      • 2766
      Wait ..... what about your E30 diff into 2002 case?
      At those prices ..... there are a lot of other options but if that works for you then go for it.
      ADAMS Autosport
      • deutschman
        • May 2008
        • 5958
        I am still going ahead with the original plans for my build. How ever if your m20 makes a shit ton of power (unlike mine) it will go threw e21 and modified 2002 diffs at a huge rate of speed!!! I know a guy who has a 2002 with a turbo m20 that went threw 9 e21 diffs. Thats why you would want this set up.
        • deutschman
          • May 2008
          • 5958
          That diff mounting plate would be sooo easy to build your self.
          • SkiFree
            • Jun 2011
            • 2766
            deutschman - Think you missed my point. What I was trying to say is that there are a few ways to get the E30 med. case diff to work with either the 2002 subframe or the E30 subframe, takes a little patience and a bit of fabricating skill.
            Either way Rob's solution is nice, for a price.
            ADAMS Autosport
            • glucklich21
              • 1912
              I lack a welder. ;)
              • mikeedler
                • 6707
                that can only come from driving like a retard!!! You would have to try to do something like that. I used to beat the living crap out of my old e21 323Is back in the day and never had a single problem.
                • SkiFree
                  • Jun 2011
                  • 2766
                  ^^I think it's a little relative.
                  For example, I shot this picture this afternoon of the underside of a Groma Race Fab. 2002. They've swapped in an entire E30 rear subframe.
                  ADAMS Autosport
                  • deutschman
                    • May 2008
                    • 5958
                    changes track width... But yes!
                    no. a turbo m20 that puts out a lot of power can go threw e21 diffs fast. i am sure he could have changed the fluid more but i dont think it was because of his driving.
                    got cha. there are a few ways. i dont have the time, space or tools to pull off a few of them right now. sadly :sad:
                    • SkiFree
                      • Jun 2011
                      • 2766
                      As your probably finding out there is give and take with everything, what might work for you might not be so hot for someone else.
                      Take the E30 subframe option for example, yes is changes the track width slightly, but in exchange you have stronger trailing arms, a subframe that was made for that size diff in the first place, and you have the ability to run a rear disk brake setup using BMW components. You can't really say one is definitively BETTER than the other.
                      Oof, I too wish I had more time for the projects, certainly learning to make the most of it.
                      ADAMS Autosport
                      • deutschman
                        • May 2008
                        • 5958
                        I was actually thinking of doing a e30 sub frame in my 2002. I probably will in the future. It really just comes down to the space I have to work with. I barrow room from my dad in his garage (I live in an apartment) so buying welders and other large fabrication tools is out of the question now. The things I could do with a bit more room. I just cant wait!
                        • Dozyproductions
                          • Jan 2007
                          • 4682
                          i use to help out at Rob's place all the time when I was in SLO. His love and dedication for BMW's is obvious in his work. You can buy this with confidence.
                          • LJ851
                            • 7918
                            I agree this is a nice piece but you are still HP limited by the little 2002 outer CVs and unless you spend another grand or so on billet stub axles and hubs those two items are known to be weak plus they are 40 years old.
                            My current plan for my 02 is a narrowed E30 rear end complete. PPF in Sweden make custom halfshafts for less than a grand.
                            Lorin
                            The M30 is God's engine.
