I'm Frustrated!
  • JOATiUBER
    • 18
    I'm Frustrated!
    It's been a while guys, between work, college, and doing a lot of work with my car recently. The reason I write today is because my driver side door is being a bitch! I rebuilt the lock cylinder, which had a key broken off in it. I was able to rebuild the new cylinder with some innovative tactics, mainly mangling it beyond recognition...Well that leads me to the whole point of this post, I cannot lock or unlock my driver side door from the door itself. Only from the trunk and passenger side door can I lock and unlock. Could this be an issue with the "Central Locking Unit", I've heard this lies behind the driver side kick panel speaker? Has anyone ever heard of this issue, if so would you kindly assist me with this bitch of a problem? Any advice, thoughts, and hands on experience would be greatly appreciated!
    1986 BMW 325e...Zinnoberot Red
    Thanks as usual :D
    "Never thought I'd ever be able to afford a car, let alone a BMW."
    I love my 325e
  • nebulous123
    • Jun 2011
    • 923
    is this a joke? it sounds like you found the problem with your situation
    '84 325e - "Elizabeth"
    '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
    • F34R
      sLaughter
      • 12376
      Masterbate?
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • ACHTUNG
        • May 2005
        • 2397
        I didn't read this
        1989 US E30 Cammed S52
        Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
        • Massimo
          • Jan 2008
          • 3207
          So you fucked up the drivers side door now you wonder why the central locking wont work on the drivers side door.
          • TurboJake
            • 3780
            Originally posted by JOATiUBER
            I was able to rebuild the new driver's side cylinder with some innovative tactics, mainly mangling it beyond recognition... Now I cannot lock or unlock my driver side door from the door itself.
            Read that. It might help.
            Leave Me Transaction Feedback
            • FunfGan
              • Jan 2011
              • 4958
              Mines been like that since I bought it... But yes, you fucked it up. Probably why its not working. Why is it such a big deal though? Doesn't bother me at all.
              Go here be happy!
              Ratchet Garage e30 V8 build.
              • dogsbark26
                • Nov 2008
                • 533
                It sounds like you must NOT have gotten the rebuilt lock cylinder attached properly/completely to the mechanism in the door.
                Note how the arm on the inside of the lock fits into the slot on the locking mechanism inside the door.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  OP, do you mean you can't move the lock knob up and down? If so, you can only lock the door this way with the door closed. I also think if you "double lock" it with the key, you won't be able to use the knob, but I'm not positive on that part.
                  • Holland
                    • Nov 2008
                    • 7212
                    Sort of OT question, but would this be the cause of strictly not locking? I've never really looked too deep into it, but my central locking works fine. It's when I lock the door it doesn't "trip" the central locking, and the driver door will just lock itself. It's also difficult to turn when locking, although I don't believe it's the lock cylinder.
                    Originally posted by DEV0 E30
                    • Vivek
                      attention whore/retard/bitch
                      • 6167
                      Wait...so you use your trunk to unlock your car?
                      Welcome to owning an e30.
                      1992 Mauritiusblau Vert
                      2011 Alpinweiss 335is coupe
                      2002 540i/6 Black/Black
                      2003 GSX-R 750 (RIP)
                      • JOATiUBER
                        • 18
                        I forgot I made this post, but for the record I should have been a bit more specific. I meant that I removed the old lock cylinder and rebuilt with another kit. The mangling that I mentioned involved cutting the back half of the cylinder off to push the key through the other side.
                        I love my 325e
                        • BrownBeanE30
                          • 965
                          Originally posted by F34R
                          Masterbate?
                          This is the answer do it and you will see the light
                          Originally posted by InuFaye
                          silver is old man color car. you need dat BRO-SECA BLUE.
                          so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
                          An S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.
                          • mkcman17
                            • Jul 2010
                            • 8240
                            at least a frat boy didn't go and break the wrong key off in your ignition, leaving your car sticking out in the street.
                            1989 LN106 Hilux / 3.0TD SFA
                            1974 2002tii / stock
                            2002 IS300 / 5spd LSD
                            • BrownBeanE30
                              • 965
                              im guessing that happened to you
