A little car troubles on this fine Friday morning..
  • miichaelsmith
    • Aug 2011
    • 300
    I leave my house..and as soon as I'm going my gas just stops. The car is still on but the gas just stops..I can put it back into 1st and accelerate got a second and then it does it again. It did it to me yesterday on the free way cruising at 80..the gas just stopped. Input, suggestions, help..please
  • blocke
    • 1305
    Define "gas just stops". You mean the Fuel cuts? Does the engine stop?
    Parts Wanted
    The Never-ending Resto Mod
    • miichaelsmith
      • Aug 2011
      • 300
      Yeah the fuel cuts..the engine is still on but im not accelerating. It happens when the cars hot and cold. Could it be the fuel pump or filter?
      • yert315
        • 2734
        Do you have gas?
        • LJ851
          • 7919
          Yes, it could.
          Lorin
          The M30 is God's engine.
          • mikeedler
            • 6707
            CPS could be going bad. would be my first guess.
            • brutus87
              • 6280
              Cps?
              • 10Toes
                Me Father Was A Tree
                • Jan 2008
                • 61222
                Crank position sensor
                • BrettsE30
                  • Feb 2011
                  • 306
                  Those damn crank sensors LOL. Check your pumps and filter. Check out any power wires to make sure theyre not rubbing on anything. I had a clip let loose and the battery wire dropped just low enough to hit the block. Oh and check your ground strap for the motor.
                  I need your obd1 parts! Harness intake ecu etc.
                  E30 Your Daily Money Pit
                  • blocke
                    • 1305
                    Also check the fuel pump relay
                    Parts Wanted
                    • miichaelsmith
                      • Aug 2011
                      • 300
                      Thanks guys for the trouble shooting ideas. It's my only car and I needed to go to work..so I took it to my mechanic. It did the thing all the way to his shop. As soon as he drove it it was fine! I was so mad. I'm gunna have to take a look at the fuel pump/filter tomorrow
                      • long tall eta
                        • Jul 2010
                        • 1536
                        does it only do it when it's warm outside? had a problem with my 325es where it would loose all power like a fuel shut off but if you goosed the engine while driving she would pick back up again. if it happened at a light it would stall and need a restart but she always did. replaced with used but known working parts.
                        fpr
                        icv
                        tb w/switch
                        coil
                        afm
                        don't know which part did it cause i did em all at once and hasen't had a problem since.
                        hope this helps.
                        • TimKninja
                          • 2131
                          Throtlle position sensor. It just stops accelerating? But the motor still runs, id say thats not a fuel delivery problem...
                          1985 325e M50TU(Sold)
                          1991 318is Slicktop (Sold)
                          1990 325is Brilliantrot S50/5 Lug Swapped.
                          1992 525i Manual shitbox Winter Beater
                          • long tall eta
                            • Jul 2010
                            • 1536
                            could be, when i replaced my tb the new (used ) 1 had a tps on it and no more problems.
                            • navid41691
                              • Apr 2011
                              • 677
                              My vote is crank position sensor. Do you have any trouble starting it sometimes?
