Rear diff whine?
  • bloodshot-e30
    • 1494
    Rear diff whine?
    alright my 3.73s are whining im wondering what would be making it happen? bearing or the acctual pinion gears? and is it gonna grenade on a long trip?
    -Josh-
    ^Back in the game^
    BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
    FS thread:
    http://www.r3vlimited.com/board/showthread.php?t=214105
  • Jaxx_
    • Dec 2009
    • 1880
    what fluid do you have in it?
    • 5Toes
      • 9836
      Thanks for reminding me of this... I believe my diff is starting to whine too... but it is weird because when my auto changes gear the whine gets softer... I would figure that the whine would stay the same because the car is moving the same speed, if not a little faster
      • bloodshot-e30
        • 1494
        ^ that might be tranny...
        and i have 75-90w what ive always used in all my diffs with the LSD oil.
        ^Back in the game^
        FS thread:
        • Wh33lhop
          • 11705
          My diff has always whined. It's pretty loud now, but I've given it about 40 thousand miles of hell and it's been fine functionally. IIRC it's the output bearings that typically cause this, and it really only happens with LSDs. Most open diffs are fine.
          paint sucks
          • Texas Toast
            • Jan 2011
            • 510
            Positive its not wheel bearings?
            Wrecking cars, closing bars.
            Tie rod spacers for sale: http://www.r3vlimited.com/board/showthread.php?t=245785
            • iamsam
              • Jun 2008
              • 174
              Usually bearings. Sometimes incorrect gear lash. Change output bearings and see if it goes away. If not, pull the lsd out, change input bearing, and a new crush bushing and re-set gear lash.
              • bloodshot-e30
                • 1494
                gotcha!
                yea those are new ;)
                awsome ill check it out thanx!
                ^Back in the game^
                FS thread:
                • Pantless Spency
                  It's McRib time!!!
                  • Feb 2011
                  • 7283
                  in my e21 my diff makes horrible noises that no human would enjoy.....
                  think loud banging squeaking and grinding. i still gotta jack it up and check her out ;) haha
                  • tjmonsen5
                    • Jan 2006
                    • 232
                    my buddies diff is SOOO LOUD. Its louder than his straight pipe exhaust, its terrible.
                    So you can buy a new bearing for it instead of replacing the entire thing? Enlighten me on where to find these bearings.
                    • Cabriolet
                      • 9620
                      miles on the diff? the clutch pack might be shot.
                      Much wow
                      I hate 4 doors
                      • bloodshot-e30
                        • 1494
                        nah clutches are still good it started to whine when it was in my 318is so im guessing its maybe 150k on it?
                        ^Back in the game^
                        FS thread:
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          I don't see this being an issue in a straight line.
                          • SoloSol
                            • May 2007
                            • 68
                            Mine is noisy too, still has plenty of grab. Ive switched out Motul and put in Redline. No change. You think its loud now? Dont take out the back seat.
                            • Holland
                              • Nov 2008
                              • 7178
                              Lol, the less sound deadening you have the louder it will be, same with poly subframe bushings, it will reverberate through the chassis.
                              Worn pinion bearings are usually the cause of whiny diffs, but if you are going to go to the trouble of replacing them then consider fresh clutches, even if yours do work they more than likely don't have as much grab as they used to.
                              Originally posted by DEV0 E30
