Quick question? e36 EWS??
  • AirplaneBuilder
    • 823
    I have a 95 m3 build date 02/95 does it have the EWS system or is it the later build date m3s that got it? I dont have access to the car right now...
    1989 Zinno 325i S50 ZF320
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    EWS II
    Starting with 1/95 production, all vehicles were equipped with a new EWS system, EWS II.
    This change was once again brought about to meet the next level of compliancy with the
    European Insurance Commission regulations.
    Purpose of The System
    Changes to the European Insurance Commission regulations made it necessary to introduce
    a new theft protection system with greater capabilities and a higher level of security.
    The EWS II system operates independent of the mechanical key. The mechanical key only
    makes a request of the vehicle starting system. Verification of the key electronically is
    required before the starting procedure is initiated.
    The system features wireless communication between a programmed EEPROM housed in
    the ignition key and the EWS II control module. A key which is properly coded to the EWS
    II control module is required before starting operation continues. The EWS II and the DME
    control modules are synchronized through an Individual Serial Number (ISN).
    The ISN, stored in the EWS II,
    must match that of the DME every
    time the ignition is switched "ON"
    before engine operation is
    allowed.
    EWS II was installed on E31, E34,
    E36, E38 and E39 vehicles.
    Major components of the EWS II
    system are:
    • Key with Transponder
    • Ring Antenna
    • Transmitter/Receiver Module
    • EWS II Control Module
    • DME Control Module
    System Components
    Four keys are initially supplied with each vehicle.
    Each key contains a wireless electronic chip
    (transponder chip). The function of the transponder
    is to receive and transmit data to the EWS II
    control module. The transponder contains a
    wireless read/write EEPROM in addition to a
    small capacitor and coil for self power capabilities.
    The functions of the EEPROM are:
    • Store codes for key identification, password and changing codes.
    • Receive and respond to coded messages from the EWS II control module.
    Power for the transponder is produced through the inductive coil and stored in the capacitor.
    Each time the key is inserted into the ignition AC voltage in the antenna ring induces
    voltage in the inductive coil.
    All keys either with remote or without, including
    wallet and valet keys contain transponders.
    8510107
    Ring Antenna
    The Ring Antenna is an inductive coil installed around the lock cylinder which provides
    power for the transponder in the key and the communication link (antenna) between the key
    and the transmit/receive module.
    The Transmitter/Receiver module supplies power to the transponder through the ring
    antenna and controls the flow of data between the transponder and the EWS II control
    module.
    Data transmission between the transmitter/receiver module and the transponder takes
    place over a radio frequency of 125 KHz amplitude modulated AM signal.
    The transmitter/receiver module converts the
    analog data received through the AM signal to
    digital data and transfers it to the EWS II control
    module over a single wire bi-directional data
    interface.
    Transmitter/Receiver Module under Dash
    The EWS II Control Module is linked to the BC, GM, DME, Trans Range switch and the
    starter for drive away protection operation. The module incorporates an integral starter relay
    and stores data and codes for communication with the transponder chip.
    The function of the EWS II module is to provide improved drive away protection for the vehicle
    and it incorporates many features of previous systems:
    • Lock out of the starter when the code function of the BC is set.
    • Disable injection and ignition through the DME.
    • Prevent starter engagement with engine running.
    • Recognition of Park/Neutral position with automatic transmission.
    New features that have been added:
    • Disable injection, ignition and starter operation until a correct key is recognized.
    • EWS and DME synchronization through the use of the ISN.
    • Release of double lock when a correctly coded key is switched on.
    The EWS II control module stores the following data
    for the key transponder inter-link:
    • Key identification code- up to 10 keys.
    • Key password.
    • Changing code- up to 10 keys.
    Workshop Hint:
    On E31, E36, E38 and E39 models the
    EWS II control module is located behind
    the glove box in the electrical carrier.
    On E34 models the module is located on
    the drivers side of the vehicle behind the
    knee bolster.
    DME
    The DME is redesigned to incorporate the new ISN code. As of production 1/95 all DME
    control modules will contain the unique ISN number and will not interchange with previous
    DME's. The following new features are added to the DME:
    • Unique ISN assigned to DME during manufacture, it can not be changed, altered or
    overwritten.
    • The BC code input to the DME is eliminated.
    • The DME and EWS II control module must be synchronized. The DME sends the ISN to
    the EWS II module which stores the number for replay to the DME.
    • The ISN received from the EWS II module during start-up is compared to the internal
    ISN of the DME. The numbers must match before the start operation is allowed to continue.
    • The ISN is sent to the DME continuously by the EWS II module with the key on.
    • The DME will ignore loss of the ISN after the engine is running.
    • The DME retains the ISN information from the EWS II module for 10 seconds after the
    ignition is switched off.
    Restarting or switching the ignition on within the 10 seconds cancels the key
    identification process.
    Principle of Operation
    The starting sequence involves communication between all the components of the system.
    Any break-down in the communication process will result in a no start condition. The
    sequence of events for vehicle starting is as follows:
    • The key is inserted into the lock cylinder and switched "ON". The transmitter/receiver
    module is powered through KL R. The transmitter/receiver module sends a 125kHz.
    AM signal to the ring antenna. The AM signal induces voltage in the key coil and powers
    up the transponder.
    • Powered up, the key transponder sends the key identification code to the transmitter/
    receiver module via the 125kHz AM signal (1). The transmitter/receiver module converts
    the AM signal to a digital signal and sends it to the EWS II control module (2).
    • The EWS II control module verifies the key identification code and checks to see if the
    key is enabled (3).
    Upon accepting the key as valid and enabled the EWS II control module sends a digital
    password (4) to the transmitter/receiver module, which converts the data to an AM
    signal (5) and sends it to the transponder via the ring antenna (6).
    • If the transponder accepts the password as correct the transponder releases the
    changing code (7) to the transmitter/receiver module which converts this AM signal to
    digital (8) and sends it to the EWS II module (9).
    • If the changing code received by the EWS II module is correct, the status of the BC,
    transmission range switch and TD is examined. With correct input status the internal
    starter relay is energized and the starter motor begins to operate (10). At the same
    time the EWS II module sends the ISN to the DME via the single wire communication
    link (11).
    • If the ISN code stored in the EWS II module matches that of the DME, the drive away
    protection is cancelled and injection and ignition is enabled.
    • During the process of sending the ISN to the DME, the EWS II module sends a new
    changing code to the transponder through the transmitter/receiver and ring antenna.
    The transponder stores the changing code until
    the next starting sequence.
    EWS II
    Replacement Procedures
    Keys
    Up to 6 additional keys may be ordered as replacement keys. The EWS II control module
    is codeable for only 10 keys (4 delivered with vehicle and 6 replacement).
    Replacement EWS II Control Modules must be ordered VIN specific. EWS II modules contain
    the VIN and coding from the factory to recognize the key codes. Modules from other
    vehicles will not recognize keys as being valid and not start the engine.
    EWS II Control Modules store the Central Coding Key (ZCS) and the VIN. If the EWS II control
    module is replaced the system must be ZCS coded (SIB 61 02 96 and TRI 61 01 95).
    The EWS II module must be synchronized with the DME (aligned). There is no limit to the
    number of times the ISN may be changed in the EWS II module.
    DME Control Module
    The DME Control Module is not ordered VIN specific and must be programmed during
    replacement. The ISN from the new DME must
    be transferred to the EWS II module using the
    DISplus or MoDic.
    Key Activation
    Keys that are lost or stolen may be deactivated
    or made to not operate the starter functions.
    The SERVICE FUNCTIONS of the DISplus or
    MoDic for EWS II contains a "Bar/Release
    Code" function that activates and deactivates
    keys of the EWS II. Any key may be "Barred"
    except the key in the ignition at the time of
    deactivation. The lost or stolen key can be identified
    by the identification of the remaining keys.
    There is no limit to the number of times a key
    can be activated/deactivated.
    Note: A "Barred" key will not start the engine, it
    will still unlock the vehicle.
