Sell it + $100 = ?
best $100 thing to do to an e30?
cover shipping fees on $2K worth of maintenance parts..Comment
m20 is plenty. im simply a drifter.
build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510Comment
TornadoComment
robInstagram: @jstnlwsOriginally posted by HarryPotternot to be racist but i've had multiple african americans comment on how they love my car. I've seen pics of e30's rolling through africa with at least 15-20 africans on them with ak-47's. WILD. its in the african blood. Hope this wasn't too racist, forgive me as I am intoxicated.Comment
Timing Belt
Tstat/Radiator
Distributor/plugs/wires
Fuel filter/fuel pump
brake rotors/brake pads/brake fluid/brake lines/clutch line/clutch bleed
trans/diff fluid
oil change/filter change
...etc. Put that $100 towards maintenance, and keep doing it. Don't stop until you've fixed everything, then start doing mods if you feel like it. You want a well sorted baseline to build from, not a car held together with bailing wire, duct tape, zip ties, and pennies.Comment
Like most of the cars here on R3V then.....
Do the timing belt and W/P, check the rest of the cooling system.
Live long
ProsperComment
EditMaintenance. Front of engine timing, ignition, coolant system upkeep. If you have records that that has been done recently then I would suggest:
IS lip
Short shifter
Subframe bushings
Clutch stop
Second trunk light mod
HID's
Clear or smoked side markers
All can be done for around $100 or less.sigpic
