Just me weeping in the corner. :(
    I dropped my car off at Castro's to get the rack and pinion and a new power steering pump done along with some suspension maintenance. While he was test driving it, it the timing belt went out and I am now $$$ poorer as a result. You may commence with the empathetic, "that sux man"'s :(
    90 325is
    85 RZ350
    75 RD350
    7? RD400 race bike
    that sux man
      s5x have a timing chain... just saying.
      -Alex
        lol so do M10s
          And M42s and S14s.
            Well, I am really on the fence about it. I cannot afford ANY service right now. BUT if I have to drop significant coin on a head rebuild all to end up with a car worth MAYBE $5-5.5k (on a good day) perhaps I SHOULD find a way to come up with 4x that head build money to drop an S52 in and be left with a car worth perhaps as much as 8-10k. Investment-wise it makes sense I just don't think I can find the cash to pull it off. :/
            90 325is
            85 RZ350
            75 RD350
            7? RD400 race bike
              M30's come with chains as well ;)
              BMWCCA # 482566
              Originally posted by nando
              also, I can't think of any BMW special tools you need to do a headgasket on an M20. you could nearly do it with the trunk tool kit, some bubble gum, and string.
              Check out my Leather Shift Boots for Sale Here
              Check out my other work with my GF Here Great gifts for your Wife or GF
                put the money into a M/S5x swap. if you cannot afford the S52 right now, swap in an M50TU. cheaper engine, and the wiring is all done when you source the motor. makes it a less than one day job to get the more powerful engine. M20's are plentiful as well, you can also just source a replacement engine (possibly with warranty) do the basic maintenance, and save coin over a reman head.
                I saved 15% on my Bimmer parts by switching to ...
                  Yeah I would just buy a new M20 for like $5 and a chicken sandwich. After looking at M50 dynos... an m50 isn't really worth the money when you look at the performance gained
                  -Alex
                    amen to that!
                    my tbelt went out when the car was at idle. opened the oil cap and saw my rocker in two pieces. It was a big FU
                    The Build:
                      i need todo timing belt ....
                        what is timing belt?
                          just drop another M20 in it and call it a day. They're like $400.
                          1989 US E30 Cammed S52
                          Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                            There should be another 50% off sale for christmas. COme out to $88 if you remove everything (manifolds, flywheel, wasser pump, etc). Then you put in a new water pump, timing belt, cap rotor, seals, spark plugs etc. So about $400 in total you have a nicely serviced m20 that will be ready to go another couple hundred thousand miles. Why did you not service your timing belt before suspension? A heart is more important then an elbow.
                            www.gecoils.com
                              I'm not intending this to be mean at all. But this is why we always say on here.
                              Timing belt>every other maintenece part. Even if the car has a locked up wheel bearing.
                              Sucks.
                              Leave Me Transaction Feedback
