i use to have a e46. lol dunno if that helps. ;) jk I would go with was Mike and Pac suggest. test it and be sure. If I am not wrong Mike works at a service center of sorts? I would trust his word.
e46 electrical problems...
Originally posted by mikeedler View Postput a multimeter on the battery with the motor off, see what the voltage isshould be about 12,0 volts, then start and see what it is, should go up to about 14,7 Volts--- yes, this is not 100% accurate, but it will help in a bind.
I also think alt. is bad.
Also, since no maintenance has been done, does it still have the original, BMW battery?
Seeing as the last e46 rolled out in 2006, the original battery would be at least 5 years old...coming down on the end of it's ~60 month lifespan. If it won't hold a charge, you can hook a multi-meter up to it and watch the voltage slowly drop.
GL!1974.5 Jensen Healey : 2003 330i/5
I have an X5 with an M54 engine - I've seen many reports of issues with the ignition switch. If you search there are diy's on how to remove and clean it internally with CRC contact cleaner spray. There are a total of 6 contact points inside of it - 5 of them need to be in full contact with each other while the engine is running. The sixth contact is for the starter.Last edited by Morrison; 12-16-2011, 11:44 AM."I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
-Franklin D. Roosevelt
We had the alternator checked and it passed. I got a spare battery thats pretty much brand new and fully charged to use for now. Im convinced now that there is something draining the battery at a fairly fast rate, time to bust out the fluke voltmeter and poke away. From what ive read on other forums is that the car will not go into "sleep mode", the FSR whatever that it is a blown blower motor resistor.
What does the voltage on the battery read? A draining battery wouldn't really cause the issue especially if your alternator is fine. I still believe your issue is a fuel issue.
If you haven't already I would invest in a Peake scan tool. It pays for itself the first time you use it.Current: 1988 M3 - Henna/Black black alcantara
Guten Parts + Service ... When you care enough to only give the very best.
Previous:
'87 S50 MTech 1 325is
'07 DTM Audi S4
'03 VF Supercharged M3
'03 Lexus IS300 (615rwhp/512rwtq)
Ok I figured out what was draining the battery after a few beers and some swearing and probing with a volt meter and turns out it was the FSU or Final Stage Unit. It looks pretty wierd all spikey like a porcupine. Bought a new one and put it in and the car has been running flawlessly for a few days now.
Originally posted by B2ThaZiZza View PostOk I figured out what was draining the battery after a few beers and some swearing and probing with a volt meter and turns out it was the FSU or Final Stage Unit. It looks pretty wierd all spikey like a porcupine. Bought a new one and put it in and the car has been running flawlessly for a few days now.
Originally posted by B2ThaZiZza View PostOk I figured out what was draining the battery after a few beers and some swearing and probing with a volt meter and turns out it was the FSU or Final Stage Unit. It looks pretty wierd all spikey like a porcupine. Bought a new one and put it in and the car has been running flawlessly for a few days now.Current: 1988 M3 - Henna/Black black alcantara
Previous:
'07 DTM Audi S4
