Shaky shaky
  • tbruz
    • 428
    Shaky shaky
    Ok so recently I've been commuting to Petaluma and I've noticed that when I'm going over 50 and hit a left curve my front right wheel shakes pretty bad, it's been getting worse and honestly idk where it's coming from...any ideas people?
  • woodisgood
    • 1087
    Likely unbalanced wheel.
    • Nick_S
      • Apr 2011
      • 3655
      Hate to be captain obvious. Make sure you're wheel is tight? Bad tie rod? Ball joint? massive play in the rack?
      Sounds like the only solution is S50 swap.
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • tbruz
        • 428
        Lmao, yea I haven't even really looked at it yet cuz I've been workin my ass off but I'm off this weekend so I'm gonna check it out. Just trying to get some ideas. Idk about the unbalanced wheel tho cuz it jus started and it's pretty bad.
        • RUFFLZ
          • Apr 2011
          • 3122
          i think it's that time of the year to rummage through your local pick'n'pull.
          serious.
          • Roysneon
            • 4505
            Seriously, it doesn't take that long to jack one corner of the car up, shake the wheel at the top and bottom, then side to side and check that the wheel bolts are tight. A shake/ vibration could be literally dozens of different things.
            Originally posted by mbonanni
            I am a pursit now.
            • YosemiteSam
              • Apr 2011
              • 1303
              Wheel bearing?
              • M-technik-3
                • 18946
                LCAB also allows shaky.
                • tbruz
                  • 428
                  Thanks, im checking everything out tommarow morning so hopefully I figure out what's wrong with it
                  • Thizzelle
                    • 4422
                    jack car up and shake the wheel, sounds like a bearing
                    "I wanna see da boat movie"
                    "I got a tree on my house"
                    • tbruz
                      • 428
                      Yea definitely a wheel bearing, so I have to buy a whole hub assembly right?
                      • mbonanni
                        • Sep 2011
                        • 6236
                        My wheel does the same. bad ball joint. ordering those and m3 control arm bushings soon.
                        And local pick n pull for s50? I do not think I would ever see one at my local yard. but maybe i am wrong.
                        • tbruz
                          • 428
                          Haha yea I doubt you'd find one at pick and pull I don't think they even have any BMWs, but I ordered a front hub assembly with bearing so if that doesn't fix it ill have to see about ball joints haha. But hopefully I won't have to
                          • Wschnitz
                            • 8089
                            Iii
                            This one has many bmws.
                            willschnitz
                            • mikeedler
                              • 6707
                              front left outer ball-joint. my car has been doing the same for about 2 months now. if it is a wheel bearing, it usually humms really loud in a curve and not shake.
