G-Force Meter for the E30
    I'd be interested.
    Are they fussy to mount? I suppose they'd need to be totally square in order to read accurately.
    1987 Mercedes 190E 2.3-16: Vintage Racer
    2010 BMW (E90) 335xi sedan: Grocery Getter
      So drove around with it last night to see how it works.
      It will read the highest g's for 5 seconds then reset, unless a high g force is read then it will display that.
      The first digit shows direction with
      F - Forward
      b - Back
      r - Right
      L - Left
      Then the other 3 digits display the g force in X.XX form. It dose not have data logging but the idea is that you can hit a corner then once you come out of it you can look down and see what g's you pulled before it resets in 5 seconds.
      Not bad for what it is. It will not fit in a air vent so it will have to be mounted in the ash tray or the area above it.
      Just to confirm there is also a reset button on it. So if it is giving you a reading while stationary you can just reset it.
        Originally posted by Emre View Post
        I'd be interested.
        No they are not as I mention it has a reset button so any funny readings can just be reset. Once I have mine mounted ill cost it up and put up a group buy.
          Interested!
          1987 325i-M60b44 swap
            Cool idea! Interested in seeing pictures of it mounted.
              So a little up date. The screen is hard to see with alot of light. Yesterday I drove around at about 2pm with over cast clouds and I could barly make out the readings. But this mourning at 8am no problems. Seems that it is hard to read the display with alot of ambient light. Ill see if there is some other alternative to this display that will be easier to read.
              On another note my car can pull 1g fuck yes :p
