can anti theft code be reset? replaced battery, car turns but won't start.
  • mongoose2231
    • Jul 2010
    • 41
    I did a search but nothing really concrete or related to my issue. So like the title says, the car sat a few days, 2 or 3 with battery taken out as it was dead. New battery in today, turns but won't start. I know it's the code, but how do I reset the darn thing. Car stuck in middle of driveway, kind of in the way. Any help is greatly appreciated. Oh, and she ran and started every time, 74k on odometer only.
    Thanks.
  • bmwstephen
    • 2463
    the code is disabled once the battery is disconnected...
    • mongoose2231
      • Jul 2010
      • 41
      ok, so how do i remedy the problem? the sucker wont start. any ideas?
      • bmwstephen
        • 2463
        so when you turn the car, does the OBC screen tell you to enter a code? what is the new battery specs?
        • e30vert
          • Jan 2005
          • 1789
          Possibly take title to BMW dealer and from the VIN number they "may" be able to provide the anti theft code for you. Call first and talk to service advisor.
          • mongoose2231
            • Jul 2010
            • 41
            yes, yes, the manual says all data is erased if no power to the obc. So how do I fix this problem? Perhaps reprogram a anew code?
            • mongoose2231
              • Jul 2010
              • 41
              ok the obc displays four dashes. I guess it wants me to enter a new code. The battery is the same as the one it had before. Different brand but same spec.
              • bmwstephen
                • 2463
                that's a pretty kick ass phenonmenon i wish mine would do that
                • Freude am Fahren
                  • Aug 2011
                  • 1190
                  I'm confused. This is an E36 we are talking about here, correct?
                  Life is too short to be driving a Honda.
                  • Freude am Fahren
                    • Aug 2011
                    • 1190
                    If indeed an E36, make sure you shifter is in neutral or park (if automatic) and push down the clutch before starting. Also try using your spare key, the chip inside of the E36 keys sometimes messes with things and you don't get a start. That's all I got
                    • mongoose2231
                      • Jul 2010
                      • 41
                      no, no, E30. it's a 91 vert. I will read through the manuial to see how to fix issue. darn car was fine before bat died. i am thinking maybe new code needs doing
                      • Freude am Fahren
                        • Aug 2011
                        • 1190
                        Since when do E30s have anti theft code?
                        • e30vert
                          • Jan 2005
                          • 1789
                          There is a code that needs to be entered on the OBC that once entered it will allow the starter defeat to be disabled.
                          It is accessed by pressing the CODE button on the OBC. You guys have never used that feature?
                          Here is some helpful info:
                          CODE Works as a vehicle immobilizer for anti-theft protection. It requires the entering of a code to start the car. If an improper code is entered (or none at all) the starter motor will turn but the engine will not start. If three incorrect codes are entered in succession, or if three attempts are made to start the engine, the horn will sound for 30 seconds. The code must be entered and set at ignition position 1.
                          To set the CODE feature for the first time, turn the ignition to 1 and press CODE. Using the 1000/100/10/1 buttons, enter any number between 0000 and 9999. (If you make a mistake, turn the ignition to position 2 to cancel.) REMEMBER THE NUMBER! Then turn the ignition to 0 to store the code and activate the system. To start the car or to cancel the feature, turn the ignition to either 1 or 2 and input the correct code. The feature will then be cancelled by starting the engine or by pressing SET-RES; if neither of the two are done then the code will be retained in memory.
                          • mongoose2231
                            • Jul 2010
                            • 41
                            well,apparently this one does have one. The manual tells of the procedure of how to set it up. But shouldn't it be optional? How the hell am I going to start this sucker now?
                            • mongoose2231
                              • Jul 2010
                              • 41
                              ok fellas, it worked. procedure was. re-disconnect battery, connect again, then put key to 1 position press code button on obc face and input new code. turn key back to 0 then back to one, confirm code and back to zero. Then start car. That easy! Should've payed more attention to owner's manual. Thanks for your help guys.
