Settling a debate
    Settling a debate
    A buddy of mine and I were having a discussion on making a track day car. It would be for autox and looking for a minimal investment. We both agreed on an e30 but the type is the issue. He says an e model (2.7l eta) that has a 3.73gear and a chip would "cream and I around the track" (i model being chipped as well). I tend to disagree. While The eta make more low end torque you tend to play around the upper end of the rev range and there is a 40hp difference.
    Perhaps each of us are bias. I drive a convertible I and he has an 4 door e. Who's right?
    Or are we both wrong and should go with a turbo m10;)
    1987 BMW 325ic - Emma
    2.7i would be my car of choice.
      2.7i?
        seta bottom end (2.7) with a 2.5 head (i) this = a 2.7i
        but it has to be a seta block to have the correct CR a regular eta block will have a low CR only good if you plan (You will haveto) boost
        Originally posted by b3albakii
        the head was okey .. and in a good mood
        no i didnt over heat it so much
        www.blunttech.com
          Eta with I top end, lose some torque gain some hp. A good balance for auto x in my opinion. Plus eta cars are significantly cheaper than I cars so you can put your money into the suspension where it really counts.
            Is this mod simple as plug and play swap with the I head? I have tried searching and surprisingly not found a whole lot on it.
              Check the M20 subforum...there's info everywhere on this.
                Interesting... Keeping that in mind...
                Stock plus chip on both which would be best
                  i would still be better
                  BroWorks.com Bro is a lifestyle
                    S54 :p
                      m20b25 is a good platform. Changing the gear ratio on a eta would most likely lead to broken rockers
                        Why not go 410 on a chipped I?
                        Yours truly,
                        Rich
                        you kids get off my lawn.....
                          It might be easier and cheaper in the long run to buy a 325is as it already comes with the S3.73 diff and all the "i" top end components for the 327i swap. Eta 2.7L bottom ends are cheap as hell.
                          Initial cost of workable condition e30 $1500 ~$2500
                          2.7L eta block < $100
                          Chip $200
                          Decent wheel/tire setup $800 ~$1200
                          Drilled/slotted rotors, track pads, fluids, SS Lines $500
                          Coilover setup with all new urethane bushings $1500 ~ $2000
                          Strut tower bars $300
                          Healthy dose of weight stripping and you'll be set.
                          Unfortunately, I don't think that's "cheap" by any means, but it's certainly do-able. Especially if two people are splitting the cost.
                          My 2c
                          Cheers
                            Bingo. Simplest and best solution.
                            -Charlie
                            Swing wild, brake later, don't apologize.
                            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                            FYYFF
                              410 and chipped i is an option... we've been waiting for a good deal on an e30. he says the power is more "usuable on the track" from an eta. I beg to differ
