powder coating trim
  • Liam
    • 753
    #31
    Industrial self etching semi flat primer is going to be way more durable that powder-coat.
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
    • flyboyx
      • 8371
      #32
      ^how is this more durable? powder coat actually seeps into the metal's pores. nothing is more durable than that.
      your suggestion may be good. in fact, i plan to look into it to see if it offers viable cost savings. it may be much cheaper, but it is certainly not more durable.
      also, primers are a problem when they get wet over time. they generally will water spot and look like crap in short order. what do you suggest to negate this? clear coat? semi gloss clear coat? wouldn't that defeat the purpose? by this point, it would probably be easier to just spend a couple hundred bucks on the powder coat.
      Gigitty Gigitty!!!!
