Spun in the rain and hit a curb - What could be damaged?
  • graphikg
    • Jan 2008
    • 1614
    Long story short, I spun and hit the right side of the car on the curb. Known damage is my front right wheel is cracked/best and tire popped, my rear right wheel is bent but tire may be okay. However, I can see my right rear wheel has positive camber so the rear wheel is off, making me think there may be subframe damage. I have not had the chance to lift the car yet and I want to fix it. Anyone have an idea where to start and what to look for?
    Luckily there does not look to be any body damage or motor damage, and I have ordered the GE group buy coilovers which I was planning to put in.
    I will be taking pics as I progress through this new project and maybe even entire rear end restore. :(
    Edit...
    Here are the pics: 3/15/2012
    Front Wheel Damage
    Wheel is offset pointing inward
    Rear Wheel damage
    Front control arm and tie rod (right side) - luckily looks like there is no damage.
    Rear wheel off - slant of trailing arm - this I feel is the only part I need from the yard other than new wheels.
    Might as well change the RTABs, Subframe bushings and the diff bushing while I am at it huh?
    The odds are that you have bent the front control arm and the rear trailing arm, at a minimum. Worst case would be frame or strut damage in front or a bent subframe in the rear. Replace the front control arms & tie rod and the rear trailing arm. Then put the car on an alignment machine and see if there are errors. It there are take the car to a good frame shop and have them sort it out.
    • 5Toes
      • 9836
      See my project thread, lol
      I bent my control arm, tie rod, bent the fender
      Cost me under $300 to fix... including new heel off a local's car, and the FCP suspension kit (which is perfectly fine by the way)
      • lambo
        Captain Scene Points
        • 10953
        I did this two days ago...missed the curb by an inch. SUCCESS@ kinda...
        • e30shmobberr
          • 1934
          did the same thing. i hit the left rear wheel on a curb at like 25, bent wheel, ripped subframe bushings, bent trailing arm. picknpull was my friend after this
          Patrick - IG:niicknac
          RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
          • graphikg
            • Jan 2008
            • 1614
            I will keep you all updated and try to get the car up on stands today. I am just so glad I am not the only one here that put myself in this situation. SO SAD...
            • bmwstephen
              • 2463
              dang man. how did you end up spinning?
              • atmobenzin
                • 151
                by being a lousy driver.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  Dorifto.
                  • lolcantturn
                    • 4588
                    Yup this. I don't know why everyone crashes their car in the rain or snow. You should be well aware that they are sub 3000lb RWD cars with only a spare in the trunk, take a corner correctly in the proper conditions. I've never had my rear end kick out unexpectedly in the rain.
                    Originally posted by TSI
                    OEM+
                    • lambo
                      • 10953
                      The E30's rear suspension design is less than ideal. Still, not an excuse.
                      • atmobenzin
                        • 151
                        If you bought the car you have to take that into consideration, even more when driving in less than ideal conditions.
                        • e30vert
                          • Jan 2005
                          • 1789
                          Replace front Control arms (Lemforder only!) front tie rods as well and new tire rod clips (needed when doing tie rods) , Might as well get some new front tie rod boots from Blunt or Levent as well.
                          Since the Control Arms will be removed and replaced it is a great time to replace the control arm bushings with offset M3 OEM units , or treehouse racing CAB's, or Ireland, AKG, whatever floats your boat.
                          Good lesson to learn!
                          • kronus
                            • Apr 2008
                            • 13032
                            I spun and totaled my car driving perfectly straight at 50mph in heavy rain. (caught a stream of water on the highway and hydroplaned)
                            You shouldn't be too quick to judge what kind of a driver OP is.
                            cars beep boop
                            • lambo
                              • 10953
                              Exactly why I said "Still, not an excuse" which you deleted in the quote...
