buying an e30
  • slammed_e30
    • 514
    buying an e30
    What are some important things to look for when buying an e30, besides the general car stuff.
    Originally Posted by Rob
    fucking hell, your car is cleaner in the damn snow than mine ever has been in perfect weather. sedans own me.
  • Clay'87IS
    • 324
    Rust. Watch out for rust. I'm sure these other guys know the specific places....like under the trunklid and stuff.
    -Jetta GLi
    • Jordan
      • 12916
      In WA, OR, CA etc we don't really have to worry about rust much, unless its a byproduct of poorly repaired crash damage.
      No snow here (next to never) and no salt on the roads.
      Eric Lukas has a fairly good e30 buyers guide on his website.
      https://mtechniqueabs.com/
      • Nick325is
        • 1409
        Rust really should not be too much of a problem on e30s. However, check the floorpans under the carpet incase water has leaked from the sunroof drains. Also, check the trunk for leaks. The taillight gaskets tend to leak sometimes as well as the trunk seal. Try to find an e30 with the service records so that you know when things were replaced. Ask when the timing belt and tensioner were replaced as well as other engine compnents. If the timing belt goes then you will wind up with bent valves and other fun stuff.
        Good luck with your search for an e30.
        Nick
