Water instead of Coolant?
  • slammin.e28
    שמע ישראל
    • 12054
    #31
    Originally posted by lolcantturn
    I need to hear the rest of this story.
    • s14pwd
      • Apr 2012
      • 116
      #32
      Originally posted by Exodus_2pt0
      On the contrary, I have personally run engines for 45 minutes without oil in an attempt to get some bearing material in the pan. Got one flake, which was good enough for warranty authorization.
      On a serious note though, i'm pretty sure your comparison only applies in a question of "should I put coolant into my radiator or leave it dry?"
      I hope you didn't just admit to some sort of warranty fraud.
      True, let me rephrase "Of course its not necessary, you could run olive oil instead of engine oil, it all depends if you want a car that runs for a few years vs who the hell knows."
      • Exodus_2pt0
        • 5943
        #33
        1.8l sentra, the rings were seized. Its a fairly common issue on those engines. The car was well within warranty, but we were close to our limit on warranty repairs for that month so we needed photo evidence of the engine failure.
        Long story short, we ran the engine without oil until it started to make some noise, then pulled the pan and took pictures of the single spec of bearing material we got to show up. It took a lllloooonnnggg time to get it to do any real damage.
        On top of that, I have seen an old Chevy 350 get run for about an hour before the tech realized there wasn't any oil in it. Company parts truck so no one cared. We topped off the oil and never had an issue.
        Engines are pretty tough as long as you take care of them.
        /threadhijack
        No E30 Club
        • Exodus_2pt0
          • 5943
          #34
          Warranty fraud would be forcing a failure to get it repaired. This engine was shot, with low compression across the board. We just had take pictures and didn't have time to tear down. No fraud here buddy, I don't care enough to take time to give some customer I don't know a free engine, unless they already needed it.
          No E30 Club
          • slammin.e28
            שמע ישראל
            • 12054
            #35
            Ever heard of the rice burner melt down. Drain all fluids from an engine and put a brick on the gas pedal. Then write down how long you think it will last. Closest to the actual time wins a prize. Usually done with Hondas, but a local air-cooled VW groups locally used a Toyota one year.
            It ran for over an hour and twenty minutes. Made all kinds of noise. It was ridiculous.
