What do you keep in your trunk?
    I like a clean trunk. What do you keep in yours?
    1. My little tool kit box, it's about the size of a textbook. It contains every tool I needed to take my engine out so it's fairly extensive but compact.
    2. OEM Tool kit missing some pieces though
    3. OEM Jack, OEM Wheel chuck, OEM tire iron.
    No coolant because I haven't had coolant troubles (knock on wood)
    No oil because, if you're low on oil then you have bigger problems and should probably get your car towed and fixed.
    Overall my trunk is completely fucking empty and I love it.
    Originally posted by TSI
    OEM+
    Empty. There's a 12" sub in the rear of the e46 (cause it was free) and an amp in the rear of the M3 (cause the stock amp died.) Normal tools that came with the car in the e28, jack, etc.
    I like a clean trunk too. I just like a clean car in general.
      Sub, fully stocked tool bag and ratchet set (electrician so tools are a must), factory jack and a thing of coolant (I have had coolant issues)
      I like a clean car too. In the main part of my car there's sunglasses, painkiller box full of condoms, misc paperwork and a gps.
        Hookers. Plain and simple.
          Same as the above with tools and whatnot but i also carry around a spare lower oil pan for my m42
          :shock:
            I have your #2 and #3 +
            -Some paper towels
            -2x12 sub box which is too big but have had it since '04 and don't want to spend $$$ on a new smaller one
            -Usually some other stuff pertaining to what I'm currently working on with the car
            I also plan to add your #1. Overall clean but probably not as clean as yours.
            instagram: @tonerrrr
            High resolution E30 Fuse Box 300dpi PNG
              A bunch of strawberries
              1991 325iS turbo
                Thought you just pretend to be one (see sig)
                  Trunk monkey!
                  1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                  2012 Passat TDI - DD Duty
                  2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                    thats my sig too
                    fuck you bro :/
                    OEM+
                      Two 12" sub. Side mounted amp. Side mount cap. Dynamat lining. All the usual tools in a e30 325i. And oil.
                        Hahahaha
                        1991 325iS turbo
                          a bunch of wet shit because tractor.
                            Forgot to mention:
                            A picnic basket, 'cause I like to eat in outside in nature, bitch.
                              Basically same as above, but you guys should invest in a fire extinguisher as well.
                              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
