Not the phone call I wanted to hear... losing 100psi compression on 2 cylinders
  • MC Hammered
    • Jul 2008
    • 2076
    Car started misfiring, thought it may be a coil pack issue so I limped the car to Blitzkrieg.
    They checked the coil packs and swapped in new plugs yesterday and no change in symptoms. Today they do more testing and find that 4 cylinders have 200psi compression, 2 only have 100psi.
    They will test a bit more and see if the issue is in the head or the block... but for now the wagon isn't going anywhere.
    My 1989 e30 s52 Touring... this is Betty
    My 1989 325i vert (sold)...this is Nina
    My 1991 M5 (sold)... this is Veronica
    Photo comparison: OEM vs aftermarket windscreen for a convertible
  • e30lov
    • Jul 2008
    • 1597
    s38 touring time
    `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
    • !kid
      • 1362
      Is it just me or does 200psi seem high? Have them do a leak down test to help pin point the problem.
      :borg:
      • nates 87 325is
        • Jun 2011
        • 124
        200 sounds really high. I think mine were in the 160s.
        87 325is
        • FLG
          • Sep 2011
          • 3165
          Does it have any work done?? Thats pretty high, should be in the 160's
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • kronus
            • Apr 2008
            • 13032
            Folks, it's an s38, 200 is a reasonable compression for it
            cars beep boop
            • MC Hammered
              • Jul 2008
              • 2076
              Actually it is a s52 and I am only reporting the info I was provided, but bottom line is 2 cylinders are losing a lot of compression.
              A leakdown test will be done next to see if the problem can be determined, but my tech said it is not a HG.
              • FLG
                • Sep 2011
                • 3165
                Than it makes sense.
                Well I hope for your sake its a head/valve issue so your not stuck doing a full tear down. Did the numbers change if they added oil to the clyinders? If they went up substantially it would point to rings.
                Sent from my Galaxy Nexus using Tapatalk 2
                • 325ix
                  • Aug 2009
                  • 7783
                  I was going to say if it isn't the HG, I would think the piston rings are to blame.
                  Also, being in canada, why do you have an S52?
                  • nrubenstein
                    • 3148
                    Two cylinders at half compression will almost certainly be the head gasket if they are adjacent.
                    2002 BMW M3 Alpinweiß/Black
                    1999 323i GTS2 Alpinweiß
                    1995 M3 Dakargelb/Black
                    - S50B32/S6S420G/3.91
                    1990 325is Brilliantrot/Tan
                    1989 M3 Alpinweiß/Black
                    • nrubenstein
                      • 3148
                      Canuckia only got a handful of early model euro M3s, before switching to our weak sauce version.
                      • LJ851
                        • 7919
                        Yep,This.
                        Lorin
                        The M30 is God's engine.
                        • MC Hammered
                          • Jul 2008
                          • 2076
                          Compression test shows fluctuating 80-100psi on cylinder 5, 80psi on cylinder 6.
                          So they did a leak down test on my wagon and the issue is in the head... either an intake valve is bent or one of the lifters crapped out. I'm hoping it is the latter.
                          Head is coming off the engine next to determine what the fault is... so any one want to take a guess?
                          • mbonanni
                            • Sep 2011
                            • 6236
                            hg
                            • FLG
                              • Sep 2011
                              • 3165
                              Originally posted by mbonanni
                              hg
