The first thing I'd suspect, especially on this engine, would be intake leaks. That is even more likely given a diagnosis that seems to point to the MAF. A smoke test of the intake and a crank case pressure check (diagnostic for a failed CCV) would be my first actions.
29 = Air mass sensor
C9 = is Lambda Control #1
FF not listed, it may have been incorrect as I was reading it in bright sun light
This maybe 1F Fuel Injector, Cyl #5
OD = Oxy sensor, #1
The codes he told me. Told him to toss the FF codes as it means jack squat prior to 95.
I mentioned that to him they are downstream so most likely it's just a nice simple fix. I won't see car till later in week but with things to check he's doing good. Wanted to put some fancy iridium plugs in it and said No stop, NGK or simple F7DLCR for it.
