I've realized something vitally important.
  • FunfGan
    • Jan 2011
    • 4958
    Originally posted by coreyw
    I don't get it, if you're buying the right tire sizes shouldn't they have the same overall diameter, thus the same ride height? It'd only be off fractions of an inch.
    No...
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • lolcantturn
      • 4588
      225/50/16, I had raise my coilovers from being all the way threaded down to being all the way threaded up to even THINK of getting the tire to clear the fender, thats where most of the ride height was gained.
      Originally posted by TSI
      OEM+
      • rightcoastbias
        • 449
        Originally posted by VinniE30
        center support bearing?
        Cool story bro, inspect your center support bearing. You failed to preload your guibo.
        M52B28 OBD1 - G240 - S4.10
        Stuff for Sale: 24v swap parts
        • VinniE30
          • 2113
          Exactly... So it's not a matter of changing your wheel diameter... it's a matter of you changing your ride height, which could have been done with your old wheels too. It's just that with the new wheels you can have a higher ride height and have the illusion of looking just as "flush" as before because you're keeping a flush wheel gap, even though you have a higher ride height.
          Zinno '89 <24v swap in progress>
          • Oly_Schmidt
            • 111
            Uh yeah, cuz 225s don't fit until you roll the shit out of the rear wheel arches.
            16s are the only way to go in my book. There's a thread here somewhere of pics. When I get the 24v on the road I'm planning to use those, shod with 215\50s or 55s.
            lolcantturn, bet your speedo works a lot better now.
            • lolcantturn
              • 4588
              I'm confused about the whole speedo thing, should my speedo read much higher than average now? I know that with my 15's, at 80mph indicated I would actually be going 76mph.
              OEM+
              • VinniE30
                • 2113
                You don't get it.
                If your overall diameter of wheels/tires is the same then your oilpan is still the same distance off the ground.
                The difference he's noticing is because he adjusted his coilovers.
                • VinniE30
                  • 2113
                  What's the sidewall size on the new tires? 225/??/16
                  • lolcantturn
                    • 4588
                    Originally posted by vinnie30
                    what's the sidewall size on the new tires? 225/??/16
                    225/50/16
                    OEM+
                    • LJ851
                      • 7919
                      225/50/16
                      Monster truck size. WTF?
                      Lorin
                      The M30 is God's engine.
                      • VinniE30
                        • 2113
                        If you went from 195/60/15 to 225/50/16 then it's only gonna be about 2 mph difference at 65.
                        use the calculator..
                        225/50-R16 tires are 0.65 inches (16.4 mm) larger in diameter than 195/60-R15 tires and the speedometer difference is 2.6%
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          Originally posted by TurboJake
                          lolaimsforpotholescantturn
                          You're doing it wrong grasshopper.
                          • lolcantturn
                            • 4588
                            OEM+
                            • evandael
                              • Oct 2009
                              • 2881
                              so you raised your car, and don't bottom out as much?
                              i see.
                              • lolcantturn
                                • 4588
                                i see.
                                I was getting away with no scrape with just wheels though
                                just couldn't turn
                                feels gewd men
                                OEM+
