MAF wiring questions...
  • jajou318
    • Jan 2005
    • 1023
    Ok so I got my MAF setup from iflytii (finally, wasn't his fault :D, btw don't use usps ).
    The wire titled "white hehe" is in actuality white. I can't paint white on a white background and expet you to see it.
  • Jordan
    • 12913
    Intake air temp sensor goes before the MAF.
    One wire is ground to ECU, other is signal to ECU. It doesn't matter which way you connect it so long as its connected to the right 2 ECU wires.
    Don't know about the ARC2 wiring as that setup is notoriously horrible.
    https://mtechniqueabs.com/
