Just got my first e30, evaluate my to-do list
  • swolfe
    • Jul 2012
    • 32
    Hey guys. Got my first e30 about a week ago, I've been really enjoying it. It's an '88 325is:
    I'm in grad school now, picking it up to use as a street car for a couple of years and then turn into a SpecE30. I mostly ride my R1 everywhere (and otherwise drive my truck, '97 F-150). I've just really been wanting a fun, cheap, manual, RWD car. It has definitely fit the bill, this thing is very consistent and controllable at the limit. Steering is slow but precise with no dead play.
    Good:
    Knowledgeable PO (completed an LS1 swap in an E34 a year ago), willing to help me work on the car down the line
    3.73 LSD (rebuilt with new clutches 5 years ago, I tested it and it was working well)
    M3 springs & Bilstein shocks
    Painted about a year ago
    Most electronics (CC, OBC) seem to work
    Complete tool kit and jack
    Chipped (Dinan I think) and have access to software for tuning
    Basketweave wheels
    Newish summer tires
    Cibie headlights
    Timing belt & water pump done last year
    Bad:
    Seats are pretty rough
    245k mi
    Some slight rust –– about a quarter sized hole in the rear wheel wells, and some rust on the outer portion of the rocker panels near the front
    Antenna sticks
    Missing lower lip on front
    A/C doesn't work/leaks, going to try recharging it today
    On my to do list:
    - Replace brake pads (Akebono front + PBR rear), flush brake fluid (probably Valvoline DOT4), rotors seem OK, new wear sensor (f)
    - Swap diff fluid with Red Line 75W90, got a little chatter at low speeds and high slip angles (lol)
    - Swap tranny fluid with Red Line MTL
    - Fix fog lights (the black tape on the fascia is holding the fog light wires in place) -- who's got the best deal on fog lenses?
    - Remove rear tint (distorted/bubbled)
    - Replace front lip/splitter/spoiler/wtf ever you call it
    - Replace ambient temp sensor (with the cheap one here on r3v...)
    - Spark plugs (NGKs), going to adjust valves at the same time
    - Air filter
    - Brake duct (when I can find a red one, probably at a yard)
    - Door handle trim
    - Hood strut
    Possible when I get more motivated:
    - SS brake lines all around
    - UUC SwayBarian 22/19mm ARB
    - Slotted Brembos/ATE blue/?? pads
    I'm going to keep anything I do Spec E30 legal since that's the goal for this car in a few years. If I wasn't, I would replace the seats. The rest of the interior is nice but the front seats are about to start cracking and the struts/springs are shot.
    Anything else you guys recommend looking at?
  • swolfe
    • Jul 2012
    • 32
    Oh, and not that I need to tell anyone here, but Blunt Tech is the shit...I forgot the 2x crush washers I needed for the diff, and emailed him a few hours later. Turns out my order went out 5 min after I placed it (awesome!), I said no problem thanks for the fast shipping....NEXT DAY I had a padded envelope with the crush washers. I'm not sure if he bribed USPS or what, because I had the washers 24 hr after I emailed him.
    • urbancynic
      • Dec 2008
      • 384
      Looks good.
      Do not use platinum plugs in this. The m20 does not like them at all. Standard plugs are great.
      If you don't have proof of the timing belt job being done, do it anyway.
      Since its an 88 you have the best upgrade opportunity ever.... Plastic bumpers are pretty much plug and play on that.
      Keep you eyes open in a junkyard for better seats. It's rare but they do pop up in yards and they are pretty inexpensive if you get them quickly.
      I ran hawk hps pads and ate premium One slotted rotors with ate super blue fluid in a mk2 gti and was very pleased with my results.
      Blunt is awesome too.
      • Herr Faust Schinken
        • Feb 2012
        • 3580
        Nice a fellow 88 owner
        88 325is Five Speed
        Lachssilber
        • swolfe
          • Jul 2012
          • 32
          Anyone know weight of aluminum vs. plastic bumpers?
          • Dsun
            • Jul 2011
            • 371
            control arms, control arm bushings (get m3 offset if its still on stock, m3 offset gives you more caster for better high speed handling) tie rods, sway bar end link and bushing
            for rear check the RTAB, diff mount (while your changing diff fluid), sway bar end link and bushings, and all other misc bushings, rear shock mount (get e46 M3 convertible ones, best and strongest OEM shock mount and fits on e30)
            if you changing your tranny fluid might as well change the transmission mount while your in there, i bet they are squishy.
            Your also missing the long chrome window trim piece on your passenger side, look out for that piece too at junk yard. Id consider shadowlining the whole window trim
            Had a smooth purchase transaction with me?
            Please share your feedback
            • swolfe
              • Jul 2012
              • 32
              Build date is the month before my birthday. :)
              Thanks for the tips Dsun. I know the ARB bushings are squishy, but I'll probably wait til I do the UUC.
              What's the best source of plastic bumpers? Junk yard? What do they typically go for?
              • nadocaster
                • Apr 2012
                • 46
                Nice catch, the car looks great.
                Working sunroof?
                • Wschnitz
                  • 8089
                  Dbs dont look bad if you get a lip and swap the black bumper surround for vert body color matched type.
                  Or do euro bumpers, look tons better then plastics (my opinion)
                  willschnitz
                  • 325ix
                    • Aug 2009
                    • 7783
                    Good luck finding a vert rear bumper.
                    • Stanley Rockafella
                      • Aug 2011
                      • 4062
                      Euro plastics are pretty much the same as the NA plastic bumpers, no?
                      • agent
                        Vice Grand Pubaa
                        • 7960
                        When I first bought mine I thought it was going to become an SE30 car as well, until I realized that these cars aren't getting any more common. In fact it seems their value is going up. Don't sacrifice an all-original iS to become an SE30 car. That purpose is much better suited for an i and/or previously wrecked car.
                        Originally posted by Dsun
                        You're also missing the long anodized aluminum window trim piece on your passenger side...
                        FTFY
                        Just helped a friend with a euro bumper swap on his Alpine II 'vert yesterday. I have all the bits in my garage ready to go into my f/s thread once I take pics.
                        Originally posted by kronus
                        • swolfe
                          • Jul 2012
                          • 32
                          Any suggestions for bodywork online?
                          • cormier
                            • 380
                            Congrats on the buy looks good!
                            Your list looks good too and other members have hit the major points
                            One thing I'll mention is most times a huge rear sway bar is overkill, the stock cabrio ones are a little thicker and work well on a budget
                            Also be sure to inspect all fuel and brake lines with a fine tooth comb. I've had a brake line pop (not fun) and this guy had his car burn down from a bad fuel line :(
                            • swolfe
                              • Jul 2012
                              • 32
                              Thanks for the tip, I looked the hardlines over pretty well with the PO. Some surface oxidation but not too bad.
                              Sunroof works but catches slightly on closing. A fastener fell out and jammed it up Friday. I can see where it goes (I think this is the reason it's catching, it's hanging a hair too low), but I have to remove the headliner portion. From what I've read they seem pretty fragile, I might just live with it.
