Bulge in tire
  • Flash
    • 691
    Bulge in tire
    I bought a set of tires of a friend recently, used. After a week one started vibrating on the highway, i figured a wheel weight fell off, no big deal. I hardly even drive so it wasnt a big issue, it started showing up at lower speeds and moving the steering wheel slightly left and right, and wore prematurely on a spot, which is now like a bump/bulge with no tread in that spot.
    What the heck causes this? Tire defect?
    Have another set im throwing on before i drive it again, just curious as this happened to my first car around 10 years ago.
  • F34R
    sLaughter
    • 12376
    The bands in the tire broke making the air push the rubber out. It wears the tread out in a bald spot manner.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • ohthejosh
      • 4963
      your tire is pregnant.
      SO MUCH MORE TO DO!!
      IG: ohthejosh
      LEGIT CHECK ME BRUH
      BUYER FEEDBACK THREAD
      • mikeedler
        • 6707
        usually it comes from improperly dismounting the tire, or in some cases, hitting a curb really hard.
        • Vivek
          attention whore/retard/bitch
          • 6167
          Yep probably a tire defect.
          ...4 posts all at the same time
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • spike68
            • Apr 2009
            • 1185
            Yes, a tire defect would probably be the best answer. the wearing of the tread was probably caused from the bump in the tire. However, i believe bumps in tires can also be caused if you hit a bump or hole in the road pretty freaking hard. It could weaken that part of the wheel and over time the pressure of the tire causes the bump.
            either way, just get it replaced. Problem solved. Its a pretty easy fix.
            I don't even own this car anymore, but I'm too lazy to change the picture.
            • ohthejosh
              • 4963
              abort that tire.
              IG: ohthejosh
              LEGIT CHECK ME BRUH
              • 10Toes
                Me Father Was A Tree
                • Jan 2008
                • 61222
                Puberty
                • ohthejosh
                  • 4963
                  Yepp. 10 years of it.
                  IG: ohthejosh
                  LEGIT CHECK ME BRUH
                  • Ayman
                    • Apr 2011
                    • 4190
                    or it has a boner.
                    Originally posted by yert315
                    Your mother is plug n play
                    • scottinAZ
                      • Dec 2009
                      • 1312
                      classic tread separation. get new tire, forget about it.
                      I saved 15% on my Bimmer parts by switching to ...
                      • InuFaye
                        • 2221
                        I never tire of these threads.
                        1986 Plymouth Horizon. Base.
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          You have to let the air out of the bulge. There is air trapped in there. You have to let it out.
                          I'm not responsible for the consequences of following my advise....but please do take a video of it and post it.
                          • dannyyisntt
                            • 3141
                            Do you often stare at bulges?
                            • IRON-E
                              • 16548
                              Keep it in your pants, you perv!
                              @IRON-E30 aka Edwin:D
