Family cruising in a cab: 318i or 325i?
  • dcdude
    • Aug 2012
    • 7
    I'm trying to decide between M42 and M20 powered cabs. If it was just me in a lighter coupe, I expect that the performance difference would be more minor, but I'm concerned that if I pile in the wife and two small kids that I might be a bit disappointed with a 318 cabriolet compared to the 325. I won't daily drive it, so the MPG advantage of the M42 doesn't mean much to me. Either car is very likely to be a 5 speed.
    Your recommendations? Thanks in advance.
    Chuck
  • F34R
    sLaughter
    • 12376
    You mean the m42, BMW only made the m10 and m42 for the BMW e30. Since the vert was made in 87 it only came in: m20b25 and m42 base engines.
    In 96 the M42 was replaced with the M44. You will want the m20, better power overall. The m42 is not bad, but is not powerful at all. Needs a turbo to be of any use IMO. I have driven the M42 and it was just boring.
    M20b25:168hp/164trq(this would be my pick, higher HP and almost b27 trq)
    M42b18:134hp/127trq
    Edit: I was smoking something strong.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • frankenbeemer
      • Sep 2009
      • 2260
      What are you smoking tonight F34R?
      Don't buy an e30
      They're stupid
      1989 325is Raged on then sold.
      1988 325 SETA 2DR Beaten to death, then parted.
      1988 325 SETA 4DR Parted.
      1990 325i Cabrio Daily'd, then stored 2 yrs ago.
      • frankenbeemer
        • Sep 2009
        • 2260
        Originally posted by F34R
        You mean the m42, BMW only made the m10 and m42 for the BMW e30. Since the vert was made in 87 it only came in: m20b27, SETAm20b25 and m42 base engines.
        M20b27:121hp/170trq
        M20b28"aka" SETA(1988 ONLY) 127hp/170trq, with the b25 head, intake and 173 ECU this is the best engine out of the m20
        M42b18:134hp/127trq
        Hmmm.
        Don't buy an e30
        They're stupid
        • F34R
          sLaughter
          • 12376
          I have no clue, my bad lol
          Current cars:
          ~ '87 535
          ~ '06 X5 4.8is
          • nrubenstein
            • 3148
            Nothing, what is the reason you think so? and you can quote my post and put it into one single one instead of a retarded "hmmm"
            He asked what engine would be best from the e30. There is 3 to pick from and one to get lucky finding. Best one out of the bunch is the m20b25 given from the higher HP and almost the same trq as the b27. I answered his question in full, and told him the 4 cylinder history. BMW never made a M45, Infiniti does though ;)
            If you mean this:
            "M20b28"aka" SETA(1988 ONLY) 127hp/170trq, with the b25 head, intake and 173 ECU this is the best engine out of the m20"
            That is not a factory engine, you should know of that simple upgrade by now. Take an afternoon start to finish if you know what you're doing, weekend if you're new to engine tear downs. If you can handle a water pump and timing belt you can do the b25 head/intake upgrade on the ETA engines.
            He's asking what you are smoking because BMW never sold the 'vert with any variety of eta engine.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • nrubenstein
              • 3148
              And to the OP: The basic answer is that both of them will be slow. Get whichever one is in the best shape and run with it.
              • SpecM
                • Oct 2005
                • 4531
                N
                If you mean this:
                b28? where are you getting this stuff?
                1989 cirrisblau-metallic 325i
                • F34R
                  sLaughter
                  • 12376
                  Like he said, "what am I smoking", I remember commenting on a 89 vert with a b27 swapped into it. I have no idea why I fucking posted that. I will fix my post to reflect the correct information. Sorry OP, I cannot believe I made an error like that. I even posted the BMW e30 models pricing on my facebook. I typed the 325i in 1987, I had a complete brain fart.
                  I have no fucking clue, from reading on here they have a larger piston. But I am on Strictlyeta.net and the bore and stroke is the same between the ETA and Super ETA. Must be the information I gathered from builds on r3vlimited is wrong.
                  325e (1984-1987)
                  ENGINE/TRANSMISSION
                  M20 2693cc SOHC belt-driven inline 6, 2 valves/cylinder, cast crankshaft
                  121 hp @ 4250 RPM
                  170 lb-ft torque @ 3250 RPM
                  Compression ratio: 9.0:1
                  Bore/stroke: 84x81 mm
                  Bosch Motronic 1.0 fuel injection w/ DME
                  Exhaust control: 3-way catalytic converter with Lambda sensor
                  325 (1988 "Super Eta")
                  ENGINE/TRANSMISSION
                  128 hp @ 4800 RPM
                  170 lb-ft torque @ 3200 RPM
                  Compression ratio: 8.5:1
                  Bosch Motronic 1.1 fuel injection w/ DME
                  I know the SETA uses the b27 crank, but I was sure the SETA pistons are larger. Searching...
                  Originally posted by MR 325
                  Super Eta crank and rods are the same as Eta parts. The Super Eta pistons are specific to the Super Eta, and the Super Eta engine uses the 885 head casting.
                  I will look at the markings on the piston domes when I pull my head on the SETA.
                  Current cars:
                  ~ '87 535
                  ~ '06 X5 4.8is
                  • dcdude
                    • Aug 2012
                    • 7
                    Thanks guys. Yeah, I'm not expecting "speed" out of either, but struggling is a whole 'nuther thing. Thanks for the input. "Buy the best maintained example" was always our advice with Porsches.
                    Chuck
                    • flyboyx
                      • 8371
                      something else to think about: the m42 cars all came with vinyl interiors. none of them have cruise control or 13 button obc. all m42's were manuals i am 97% sure.
                      all m20 cabrios came with leather sport interior, cruise, etc.... but usually came with an auto trans. all this can be retrofitted one way or the other to either car. only the 91's and 92's(93) came with the late style facelift body style which is more desirable.
                      unfortunately, 91 to 93 m20 cars came with a power top. those are maintenance nighmares.
                      Gigitty Gigitty!!!!
                      • scottinAZ
                        • Dec 2009
                        • 1312
                        best answer:
                        Get a good straight example, and 24v swap it. No lack of power, and a better engine to boot. :D
                        I saved 15% on my Bimmer parts by switching to ...
                        • dougie30
                          • Apr 2012
                          • 1708
                          325i
                          M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                          • robrez
                            • Jul 2008
                            • 3376
                            I love the m42, but the type of driving you are contemplating will probably not make you a happy person in the m42 cab, ie. extra weight, AC on, shifting at low RPMs, not tossing car around. A 4.45 diff swap might help, unless you plan to do a lot of highway driving.
                            January 2012 COTM
                            • Mossman
                              • Apr 2006
                              • 1961
                              If you're gonna leave it stock I actually think I'd take the m42 car. Lighter, more nimble, better mileage, but you really need to ring it out a lot.
                              When I had both a bone stock 318ic on 14" all seasons and a modded 325ic on koni's, H&R sports and sticky 17's, sometimes I'd prefer to drive the 318. The lack of weight over the front end is really noticeable, and I could take turns almost as quickly despite having a serious grip disadvantage.
