How to remove these without breaking them? Hood insulation rivets
  • 5Toes
    • 9836
    http://www.ebay.com/itm/51481915964-...#ht_4647wt_910
    I broke a few today and am a bit pissed. Any suggestions?
  • burkey001
    • Feb 2011
    • 608
    trim pry hook set
    plastic
    $5
    best things ever
    like these - http://www.newmantools.com/bojo/index.html
    the 3rd one
    88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
    90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
    • der affe
      Technical
      • Dec 2005
      • 8452
      Matco sell a set of pliers for just that. There are two in the set and it runs around $40.
        Those plastic parts are +20 year old and were in a hot environment. Expect them to break and have new ones on hand for re-assembly.
        • agent
          Vice Grand Pubaa
          • 7960
          This. ^ They're not expensive.
          Originally posted by kronus
          • lambo
            Captain Scene Points
            • 10953
            I got all of mine out with a small screwdriver without breaking any of them.
            • 5Toes
              • 9836
              Well I pried a few out with a screwdriver, but I am confused. It seems whoever put them together did it wrong because both parts of the rivet are on top of the insulation...?
              • der affe
                Technical
                • Dec 2005
                • 8452
                That is correct. The middle part of the rivet expands the shaft to lock it in place. Don't split the top two pieces.
                • EyExR
                  • Jan 2011
                  • 959
                  Pry up with a screw driver and then pull off with needle nose pliers. That's how I do it anyway...
                  My 325iX DIY Threads:
                  Front Wheel Bearing Replacement
                  325iX Rear Subframe Bushings and MUCH more w/pics!
                  325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
                  • lambo
                    • 10953
                    Some of mine split and I just put em back together and they seem to work fine...
                    • 325ix
                      • Aug 2009
                      • 7783
                      Same, I take them apart all the time.
                      • F34R
                        sLaughter
                        • 12376
                        I ripped all mine out and threw away the insulation shit.
                        Instagram: @BWeissLeather
                        Current cars:
                        ~ '87 325 M30B35 swap
                        ~ '87 535
                        ~ 01 540 Msport 6spd
                        ~ '06 X5 4.8is
                        • DRTSRFR
                          • May 2008
                          • 1836
                          ...and the centers unscrew on the factory pieces. Mine pop right out once I unscrew 'em.
                          Suspension tips here...
                          http://www.r3vlimited.com/board/album.php?albumid=757
                          • 5Toes
                            • 9836
                            Mine dont unscrew, the center pin is unthreaded
                            • der affe
                              Technical
                              • Dec 2005
                              • 8452
                              I was refering to sandwiching the hood insulation between the 2 top pieces, not taking them apart.
