Synthetic and Non-synthetic motor oil
  • Victor_PR
    • Jun 2011
    • 296
    My car currently has Mobil 1 Synthetic oil in it. Since I have a pretty bad crank case leak, I have been refilling with the same type of oil. Until I can take the car for the leak repair , can I refill with normal non-synthetic oil? It is less expensive. I drive the car 80 miles a day.
    Any thoughts?
    Thanks!
    Victor
    Victor
    Rides...
    E30 325i - 1990
    F30 328i - 2014 (DD)
    F25 X3 - 2016 (Family car)
    1974 - 2002 (The ruler of the stable) SOLD
  • mr.vang
    • 4371
    throw in some thicker oil will also help with the leakage
    • Victor_PR
      • Jun 2011
      • 296
      Could it be non-synthetic mixed with the synthetic that's already in the car?
      Or do I need to do a complete oil change from synthetic to normal?
      Victor
      Rides...
      E30 325i - 1990
      • DrJosh
        • 2011
        Do a complete oil change
        Originally posted by Sonny
        I am a meme for our community.
        • FLG
          • Sep 2011
          • 3165
          Makes no difference but if you run the car its whole life on conventional and switch to synthetic the added detergents will usually clean any built up gunk around gaskets and cause leaks.
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • mr.vang
            • 4371
            i have mixed synthetic and non-synthetic before and it doesn't seem to have any problem. some oil are half synthetic such as castro blend.
              Mixing synth and non-synth isn't a problem.
              There is no advantage to running synthetic in an E30 and one disadvantage. The major advantage of synthetic is the slower rate of breakdown of the oil, allowing for longer oil/filer change intervals. An E30 should see the original change intervals, regardless of what oil you use. So the major advantage of synthetic is lost. The disadvantage is that these engines need high ZDDP content, which is very hard to find in a synthetic. Valvoline VR1 20w50 is the most readily available oil with reasonable ZDDP content. Brad Penn is better, but harder to find. Rotella T used to be good, but the word is that it's ZDDP has been reduced.
              • Emre
                • Sep 2007
                • 1228
                You have no reason to worry. Synthetic and non-synthetic can be mixed without causing any problems at all.
                Besides, Mobil 1 isn't really synthetic anyway: it uses a Group III (refined petroleum) base stock, as opposed to true synthetic motor oils based on Group IV (PAO) or Group V (usually, ester) stocks.
                1987 Mercedes 190E 2.3-16: Vintage Racer
                2010 BMW (E90) 335xi sedan: Grocery Getter
                • stamar
                  • Apr 2011
                  • 1362
                  mobile 1 15 50 has enough zddp and it is a pao true synthetic
                  only mobil 1 5-30 and 10-30 are not true synthetics.
                  in fact its totally the opposite, almost all synthetics have enough zddp the oils that do not are all dino oil.
                  most 20-50 oils have enough zddp and all listed synthetics do.
                  at 1200 ppm mobil 1 15-50 is the perfect oil for an m20./
                  and of course there is the million mile ad where they used it.
                  still the same amount of zddp as the 80s.
                  valvoline full synthetic has more than enough zddp, and castrol edge.
                  whether or not your engine can keep oil clean long enough to have a longer oil change interval isnt known. even if you had the best oil in the world if your engine is worn it will get dirty too fast to matter.
                  mine makes it farther on full synthetic but not a lot.
