Any Safety wire pros?
  • craiggroves91
    • Oct 2009
    • 3024
    Is this acceptable?
    I've done it like 80 times. I can't seem to get rid of all the slack
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
  • bimmerkarl
    • Mar 2005
    • 222
    looks like it will hold fine, I'm going to assume that is a reverse-thread fastener... safety-wire pliers can help you generate an amazing amount of force if you use the angeled side of the tip as the fulcrum to pull a single strand tight while using the free hand and other strand to lock it in place with a few twists... (hard to explain without showing you...)
    • craiggroves91
      • Oct 2009
      • 3024
      Yeah its reverse thread
      It should be fine, Its just another level of security anyway. Have red locktite on there too
      1989 BMW 325i SOLD
      • tH16
        • 236
        The beginning of the twists you may not want to go as tight because it could ruin the integrity of the wire, you only want to go 4-6 twists per inch. Once you connect it to the cog, you want to start as close to the cog as possible to eliminate the slack. Your point of strength is the twists after the cog.
        • LJ851
          • 7918
          The twist looks a little tight as mentioned above but it looks like it will hold, what size wire are you using?
          Lorin
          The M30 is God's engine.
          • craiggroves91
            • Oct 2009
            • 3024
            .032 I believe
            I just sealed it all up. too late to go back now! haha
            1989 BMW 325i SOLD
            • LJ851
              • 7918
              .032 is burly, you should have no problems.
              Lorin
              • M-technik-3
                • 18946
                Only concern I see is the ding but as you said it's sealed up.
                • craiggroves91
                  • Oct 2009
                  • 3024
                  Yeah I was mad about that too. I think its from the safety wire pliers
                  1989 BMW 325i SOLD
                  • M-technik-3
                    • 18946
                    I will be fine don't worry.
                    • jo3y
                      • Nov 2011
                      • 80
                      is that reverse thread?
                      MR2/Camaro Strut DIY
                      http://www.3seriestech.com/viewforum.php?f=22
