Quick clutch question
  • dwforum
    • 220
    Posting this in the wrong place in hopes of getting a quick response tonight. I need to drive about 100 miles tommorrow, but just today I noticed a slight whirring noise when I depress the clutch pedal that stops immediately when I release the pedal and the clutch engages. Obviously I will get it checked out soon, but is there likely any danger or major problems in driving it a bit in the current condition. The clutch feels fine, the only sign of a problem is that whirring noise when it is disengaged. Thanks in advance for any input.
  • redcarbon
    • Apr 2005
    • 213
    Sounds like your throw out bearing is on the way, uh, out. Mine made the same noise as yours for a few months and a thousand or so miles. You *should* be fine but make sure to have a back up plan if it does take a crap on you. I was able to drive mine fine even when the throw out bearing was seized, just not a nice sound and not recommended.
    318is -gone-
    • AndrewBird
      The Mad Scientist
      • 11892
      Is there any vibration in the clutch pedal when the pedal is depressed? If so, it's the throw-out bearing. You can drive on it for a pretty long time, so don't worry about it. Just replace it soon.
      • p nut
        • Dec 2005
        • 99
        If it does crap out, you can always rev-match shift. :)
        WTB: 89-91 325iS 5-sp. (Or 318iS). No rust!
        • dwforum
          • 220
          haha. well, as the noise just started last time I drove, ideally it won't. Not to mention I really only need to shift maybe 10 times to make it home as its nearly all freeeway. But I figured out a backup plan as I have a friend heading in the same direction four or five hours behind me, so hopefully all will work out.
          • redbull 325is
            • 7471
            if the slave craps out (after a month or so of starting to vibrate when pressed) you can't drive the car as it usually seizes.. sometimes making it impossible to disengage the clutch (ie put power to the wheels)
            you should be fine though
            good luck,
            Julien
            Build Threads:
            • Hawk
              • 549
              Not to hijack the post, but mine makes a rattling sound when you depress the clutch. And has for the last 30k is that a bad throw out bearing too.
              Summer '85 E24 635csi Winter '88 E30 325iX, I lose 25% of my hp before I even turn the key.
              • Dave
                E30 RAT
                • 11675
                diego says "paint your pressure plate blue" . . .
                Current Cars
                2014 M235i
                2009 R56 Cooper S
                1998 M3
                1997 M3
