New to E30's
  • chudson91
    • Nov 2012
    • 31
    New to E30's
    Well after my buddy having 3 e30's i decided to join the game.
    So i purchased a 89 325i and was known overheating when i got it.
    Car does not over heat any more.
    So tell me what should i do now.
    Here is what i have done so far:
    -New headgasket(machined the head)
    -New waterpump
    -New timing belt
    -new radiator
    -New plugs
    -New intake boot
    -New IM, EM, and coolant gaskets
    -Sport seats
    -Both coolant temp sensor and sender
    -New fuel regulator
    -New alternator
    -New fan clutch
    -New Tstat
    -Air Ride suspension
    -xxr wheels
  • dnguyen1963
    • Nov 2011
    • 2649
    So...what's the problem or you're just looking for things to do?
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5556
      Put bottle caps back on it.
      • Wschnitz
        • 8089
        XXR's... what kind? Air ride might be cool with the right wheels.
        willschnitz
        • iamsam
          • Jun 2008
          • 174
          Yeah I think air ride will definitely fix your overheating problem.
          • semaj4712
            • Mar 2012
            • 3069
            Pics of said car?
            29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
            72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
            Gewerkschaft der Polizei Sticker/Clings For Sale $8
            • N2MYE30
              • Oct 2007
              • 5536
              Im not seeing a new thermostat on the list. Also, are you sure there is no air in the system (engine)?
              COTM
              • lambo
                Captain Scene Points
                • 10953
                Here's a great write-up on bleeding the cooling system. I've used it multiple times.
                Originally posted by jlevie
                The ballooning of the hoses sounds like excessive pressure in the cooling system, which could be from a small head gasket leak that is pumping air into the cooling system. It also sounds like the fan clutch may be bad.
                With the engine and radiator at operating temperature drag a rolled up newspaper against the fan blade tips. A good clutch will shred the newspaper before you can stop the fan.
                A simple check for a head gasket leak is to fully bleed the cooling system (procedure below), drive the car for a bit (but don't let it overheat), and rebleed. Release of a significant amount of air then or on a subsequent bleed is evidence of a head gasket failure. Another clue would be hard radiator hoses after the car has completely clooled down.
                1) Using ramps or a jack get the front of the car 1' or more higher than
                the rear. That will make the radiator and bleed screw the highest point
                on the engine and facilitate removal of air.
                2) With the bleed screw open, add coolant until no more air comes out of
                the bleed.
                3) Leave the filler cap off, or at least loose, and set the heat for max
                temp and fan speed. Leaving the cap loose will prevent air that's still
                in the system from causing a "coolant fountain" once the engine heats
                up. Start the engine and allow it to warm up to operating temp. As it
                warms up occasionally crack the bleed screw to release any air and top
                up the coolant as necessary.
                4) Once the engine is at temp bring it up to 2000-2500rpm for a few seconds
                several times. Then crack the bleed until no more air is released. At
                this point the heater should be throwing lots of hot air, which
                indicates that the heater core is filled with coolant. You may have to
                repeat this a few times to get all the air out.
                5) Drive the car a bit, allow it to cool back down, and recheck the
                bleed for air. Over the next few days you may get very small amounts (a
                few bubbles) of air out of the bleed screw.
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5556
                  Does it still overheat?
                  • sector6
                    • 909
                    Fan Clutch
                    • dougie30
                      • Apr 2012
                      • 1708
                      Originally posted by semaj4712
                      Pics of said car?
                      M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                      • e30jake
                        • Feb 2012
                        • 855
                        What it feels like owning an e30:
                        88 325 S50 swap in progress
                        90 325ix
                        • ELVA164
                          • 4861
                          ....Welcome to R3V though!
                          • chudson91
                            • Nov 2012
                            • 31
                            Dang i forgot to mention the Tstat is new and fan clutch.
                            Also the car does not overheat any more either. i bleed the system of air and its all good.
                            Im thinking my icv is dead tho, car drives good and what not but it idles weird.
                            • ELVA164
                              • 4861
                              ICV could be the issue, but a weird idle could also be due to vacuum leaks or gunky injectors.
