Damn clutch hydraulics!
  • CarsSuck
    • Oct 2005
    • 968
    Cluth master or slave has failed on my '89 325is. Total bummer considering I just did the whole timing belt, water pump ordeal and completed replacing every coolant hose in the engine bay. That and i just installed the MarkD chip and 19#ers last week. I was actually really suprised it worked well enough to get me home from work. As soon as i parked, i tried to put it in first ( weak ass ebrake) and couldnt. If thats not luck (or my car loves me back?) i dont know what is.
    So no fluid in the footwell means master, right?
    --Will
  • Jordan
    • 12916
    Slave
    https://mtechniqueabs.com/
    • CarsSuck
      • Oct 2005
      • 968
      Well that would save me $50 bucks. I guess ill call BMA for a quote on one, see if it beats my dealer discount.
      --Will
      • RobertK
        Kicked cancer's ASS.
        • Jun 2005
        • 5864
        If it's the slave cylinder it's an easy fix.
        • Avus E30
          • 3650
          easy fix but watch out the clutch master cylinder went out at the same time on me.
          HDE30 <3
          • thejimlab
            • Oct 2004
            • 588
            Mine has been eating fluid for a couple days now, leaves little puddles everywhere. Clutch still works fine, just have to keep adding brake fluid. Hopefully I'll get to it this weekend.
            • erik325i
              • Jan 2005
              • 3567
              Originally posted by Jordan
              Slave
              Could still be the master. Just because there is not a massive puddle at your feet, doesn't meen that the master is still fine.
              -Erik
              • Axxe
                • Aug 2004
                • 3355
                I had that, thought all i needed to do is add fluid, and then one day, bam, wouldn't hold fluid anymore (seal went on vacation). Replace it ASAP so you don't get stuck.
                Keep it slideways!!
                • thejimlab
                  • Oct 2004
                  • 588
                  I just took a better look, it's my clutch master cylinder. Dammit.
                  • RobertK
                    • Jun 2005
                    • 5864
                    You can usually pick one of those up at a local Advance Auto Parts for $35.
                    • thejimlab
                      • Oct 2004
                      • 588
                      I really wish that were true
                      • CarsSuck
                        • Oct 2005
                        • 968
                        Well im just gonna do both the master and the slave. If one is okay, it wont be for long and i dont want to get stranded somewhere terribly inconvenient. I can get the slave for that much and the master for about $50 because my brother is a mechanic and gets wholesale prices. Anybody know off the top of their head who the OEM was?
                        --Will
                        • Jordan
                          • 12916
                          Febi or FAG?
                          • Axxe
                            • Aug 2004
                            • 3355
                            FAG IIRC for clutch hydraulics. Actually, I'm 100% sure that FAG is the slave, I'd assume master is the same.
                            Keep it slideways!!
                            • 318isbmw
                              • Nov 2005
                              • 2843
                              thankfully when mine went out it was after not driving the car for a week and it was in the garage at home.
