89 325is R-Title help
  • psmura
    • Mar 2012
    • 119
    Hey guys just drove out to check out this 89 325 is from craigs and basically made a commitment to buy at $1600. Came home and ran the vin and it was salavaged :( I was so anxious to buy that I didn't even think to run the vin first.
    So here is the info on it.
    I have a BMW 325is 166k, 5 spd..rear wheel drive, 635csi motor and transmission installed. Needs a little TLC. Dented front fender, needs e-brake cable, alignment. Solid car, nice project. No Trades $1800
    Engine::
    M30B34 bottom, B35 Head, B35 CAM, B35 sensors, B35 engine harness
    Head was rebuilt after a rocker broke 40k ago
    All gaskets redone at the head rebuild, tchain checked, waterpump
    Running m1.3 ecu from '90 535i, Dinan Chip
    Full exhaust from manifolds back, No cat, Has res+muffler
    Funkmaster mounts, firewall was banged in some behind head to fit cant see it unless motors out
    BEHR rad last year, fan delete with electric fan installed, switch where the AC switch used to be
    635csi trans
    M5 clutch, has about 20k, grabs just fine
    New clutch master 3months ago, slave last year
    New hardlines front to back
    7 series larger brake master/booster
    ABS delete (still have unit)
    Pads/rotors a year ago
    1.5" lowering springs (less than 1k miles, may settle more)
    Bilstein rear shocks
    Recaro Sport interior, Has some rips, rear is good
    No radio, but i have a alpine i can include
    NO a/c, blower motor isnt plugged in but its all is hooked up so will work
    Tach wire was never spliced in
    Factory BBS basketweaves
    Kumho tires have less than 1k miles
    Car runs great has a bit of work that needs to be done, little bit of surface rust but nothing major. Apparently the guy had no idea since he never actually registered it. He is going to look at it on a lift tomorrow and align it.
    He is a car guy and was one of the most legit people I have met on craigs. How much would you pay for the car. He said he'd come down a bit.
    1989 325ix
    1992 325ic 770A
    2002 M3
  • nrubenstein
    • 3148
    At this point, r-title is only meaningful in terms of resale value. If you can get a few hundred bucks off for the r-title, yay. Otherwise, the big question is whether or not it has any real damage and how much of a pain it will be to register/insure. In some places that's an issue, especially with a swap.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • obes
      • Apr 2012
      • 1156
      yea should've ran the vin
      but then again...a clean title...clean late model doesn't go for that cheap...
      lol
      -1986 S50Turbo Sedan (475WHP/417WTQ) Castromotorsport Built (Sold)
      -1987 Coupe (17x10.5"/17x14")
      Castromotorsport / Buddha_Concept_designs Built *UnderConstruction*
      Follow me on Instagram: obes_sebo
      For more updates:)
      Purchase FeedBack http://www.r3vlimited.com/board/showthread.php?t=278838
        A salvage title on a 20'ish year old car might, or might not, be meaningful. It all depends on how the car acquired that status and when. If it was in an accident recently, a relatively minor "fender bender" that did only sheet metal damage to replaceable parts could be the reason.
        • psmura
          • Mar 2012
          • 119
          Car shouldn't be a problem to register at all here in NY since they won't do any further inspection of it. It happened in 2006 in DE but there was no accident reported on the AutoCheck here is what it says:
          01/10/2005 YORK HAVEN, PA 114,336 Motor Vehicle Dept. TITLE (Title #:60910076)
          SALVAGE
          POSSIBLE TOTAL LOSS - VEHICLE TITLED/REGISTERED TO AN INSURANCE COMPANY
          09/25/2006 DOVER, DE Motor Vehicle Dept. TITLE (Title #:U0639338)
          RECONSTRUCTED
          11/07/2007 GREENWOOD, DE Motor Vehicle Dept. TITLE (Title #:00909644)
          RECONSTRUCTED
          Just wondering what you guys would pay for it or if you would just pass at $1500. The swap seems done well and it pulls hard. What real damage should I look for? Guess I wouldn't restore this like I had in mind but would be a fun drift/Autocross car
          1989 325ix
          1992 325ic 770A
          2002 M3
          • nrubenstein
            • 3148
            SALVAGE
            RECONSTRUCTED
            RECONSTRUCTED
            $1,500 for a decently executed (if it is) M30 swap in a decent shell, even if the title is branded is fine. What's a few hundred bucks? If anything, a car that you can tell yourself not to spend money on because it's got a branded title could be a plus.
