Premature tire wear
  • bowtie2bimmer
    • 830
    Premature tire wear
    I bought Falken Ziex 912 back in Feburary. So less than a year on them. I was adjusting my parking brake today and noticed that my insides are worn to the point of belt showing. Now I know these cars when lowered get negative camber. But mine is stock height. What could cause this?
    Bushings are old and that is the only logical explanation i can think of...
    Sent from my DROID RAZR using Tapatalk 2
    1987 BMW 325ic - Emma
  • Cabriolet
    • 9620
    bent trailing arm. :/ and open dif
    Much wow
    I hate 4 doors
    • E30Gus
      • Jun 2008
      • 781
      Yeah most likely sloppy bushings.
      • bowtie2bimmer
        • 830
        The diff is open but both sides are similar.
        My car sites no sign of a rear end collision (visually or via carfax)
        Would it just be the TA bushings causing this? With my tax return I am doing new bushings all the way around any way...
        • gtdragon980
          • Jun 2008
          • 1808
          Do you drive the car hard? Those tires have a really shitty tread life, I can say that from experience. Very grippy on dry, but wear down in about a year or so.
          FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
          Originally posted by scabzzzz
          I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
          1989 325i - Project/weekend driver
          2002 325i - DD
          2005 Suzuki SV650 - Toy
          • evandael
            • Oct 2009
            • 2881
            the subframe bushings too. since you're already replacing everything, go for it.
            • Cabriolet
              • 9620
              http://www.akgmotorsport.com/catalog...g.php?item=151 and new TA+subframe+trans bushings. should help
              Much wow
              I hate 4 doors
              • bowtie2bimmer
                • 830
                [quote=gtdragon980;3548296]Do you drive the car hard? /quote]
                Its a cabrio w/auto trans. You can say I drive it hard. It makes alot of noise but doesn't really do anything LOL
                • bowtie2bimmer
                  • 830
                  i've seen the weld on camber adjustment kits before but my car is stock... One would assume the car wasn't cambered out from the factory
                  • Cabriolet
                    • 9620
                    no but the camber kit can fix bent trailing arms. nearly every e30 i've ever seen has had at least 1 bent trailing arm, if not both.
                    Much wow
                    I hate 4 doors
                    • Wschnitz
                      • 8089
                      Really? They are rated to 85 thousand miles. Mine are still good after 2 years.
                      willschnitz
                      • andrewm
                        • 456
                        I sure hope they get more miles than that, I put mine on in March and have got about 3k miles on them.
                        1987 Delphin 325e Sedan - Natalie
                        1990 325i 24v
                        1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
                        • BoxDriver86
                          • Jul 2009
                          • 912
                          x2 on subframe bushings.
                          Since there is no adjustment on camber from the factory, this usually comes down to slop in the bushings causing your rear suspension geometry to be out of spec under load. That does look a little extreme so I would be concerned about a bent trailing arm.
                          Once a tire wear pattern is established, it is there for the life of the tire. In addition, the tires you are running will wear more quickly at extreme angles. If you don't do the bushings before you get new tires, make sure you rotate very frequently. It won't fix the problem but it will help.
                          • Emre
                            • Sep 2007
                            • 1228
                            Could be a toe problem.
                            1987 Mercedes 190E 2.3-16: Vintage Racer
                            2010 BMW (E90) 335xi sedan: Grocery Getter
                            • gtdragon980
                              • Jun 2008
                              • 1808
                              There might be two different versions with different treadwear rating, but I believe mine was rated at 65,000mi. I put them on and drove it like a go kart for a year and they wore down by the 2nd year. No where close to 60k was put on those tires. I find it hard not to take corners a little faster than normal with stiff suspension :p
                              2002 325i - DD
