interior lights dont come on
  • bmwmike
    • Sep 2004
    • 561
    the lights are switched to the correct position and when i open either the passenger or driver door, the lights inside dont come on? I could see if one door sensor didnt work but both?
    www.rimstrader.com
    all the parts you need to swap the M30 into your E30 here-> http://www.r3vlimited.com/board/show...ght=m30+mounts
    99 540i/66 911
  • marakka
    Euro Parts Pimp
    • Apr 2005
    • 2036
    It happens. Both mine don't work. Try wiggling them to see if they work when they are wiggled. if so then thats your culprit.
    • mrsleeve
      • Mar 2005
      • 16387
      well thats better than in my cavliear, the dome light wont shut off had topull the bulb.
      Originally posted by Fusion
      William Pitt-
      • bmwmike
        • Sep 2004
        • 561
        in the m5 i wiggle it like you said, didnt really work in the e30..suppose i should check the fuses
        www.rimstrader.com
        99 540i/66 911
        • bimmer8604
          • 3017
          burnt out bulbs, bad connections, sticky door sensors.
          kyle
          1988 M3, 97 840, 99 XJ
          DILLIGAF
          • rs4pro3
            • 5808
            my 85 318i had this problem for a long time, the connector the interior light delay module down under the d-side speaker had gotten corroded, I had to finally replaced the entire connector to get the lights working as they should.
            85 325e 2.7 ITB'd stroker
            • hamann318is
              • 3382
              Does the switch feel sloppy?
              Mine had this problem for the driver's side. Turns out the switch was broken, and I just bought a new one.
              The BMW 318 is back. With a vengeance.
