L31 loose rocker arm
    97 k1500 crew cab L31 (Vortec 350), 240k miles
    Over this weekend I changed the lower intake manifold gaskets due to the leaking gaskets, pretty straight forward. Truck has never given me trouble outside the fuel injectors clogging, which I replaced with the updated delphi system.
    During the reassembly, about 98% done I'm putting the bank 2 valve cover back on and notice that one of the rocker arms is loose on cylinder #2. Crap. I didnt see anything unusual when I had the manifolds off, but I didnt really feel aroudn for anything.
    Now, from what I've read the pushrods on the L31 are fairly weak, and usually bend/break before the valves do. I've not taken the L31 apart past the lower intake manifold, but I assume I will need a special service tool to remove the push rods, and I have to take the lower intake manifold off again...
    She ticks when she's cold, but once warmed up it goes away. I have not yet set the timing with the PCM tool, but if I have to take the distributor out again, I don't see any point in taking it to a shop to set the timing just yet.
    Barring a bent/broken push rod, the spring looked okay. So if the pushrod is solid and undamaged, I'd be looking at a bent, or burnt valve. Which the thought is just weighing me down.
    Thoughts?
    I can't access fullsizechevy at work, it's a blocked site...
    1987 Delphin 325e Sedan - Natalie
    1990 325i 24v
    1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
    Can you not remove the offending rocker and pull the pushrod up from the top of the valvecover?
    I know you can on a LS motor. And these are Hydro lifters so you cant necessarily say that it is loose when it has had time to leak down.
      You can, but I think the trick is more about the lifter coming off the seat and falling in. I remember that from somewhere, but I'm not 100% sure. I tried searching for the answer to that, but I'm not finding anything to support the answer.
      The fact the tapping goes away after a warm up makes me think I have a collapsed lifter, to be honest. Might be that once the oil thins out it starts to get better. Not sure how I feel about that since the motors have notoriously weak push rods and typically outstanding lifters...
      Edit, this is annoying me. I keep trying to double check my memory, but you're right. For the old school SBC you dont need to take the manifolds off, nor for the LS series. Why I remember this for the L31 I cannot fathom. That's what irks me, to remember one specific motor that you cant do it on? Just makes me think I remembered that for a reason!
      Like the fuel pumps on 7.3l ford diesels, when you remove the fuel pump, hold the valve tight...
      1990 325i 24v
        The lifter sits right on the cam and is in its own bore so I don't think it can go anywhere when the pushrods are removed. I'd pull those pushrods and check them. If they are straight (roll the on a flat surface) then maybe the lifters need to be changed.
        But Chevy motors are known to e "ticky" either lifters or piston slap.
          Yea, I'm gonna pull it this weekend I think - It doesnt sound like piston slap to me, it's much closer to the sound of bearing rattle/slop. Just not in the right spot. But you're right about Chevy motors are notorious for their ticking, especially in the cold.
          1990 325i 24v
