Yoo I recently changed my belts in my 1987 bmw 325e because of a loud noise coming from the front area, wanted to know what exactly it was, because that sound is still occuring thanks alot here is a video below...I also sprayed down the fan clutch and what it connects to with wd-40 and you can here the change but reverts back to the noise.
Noisy loud squeak, rumbling and buzzing sound
mine was making this noise as well..take the fan and fan clutch off and see if its makes any noise when you turn it by hand or if theres any play in the bolt..may just be a bad fan clutch..if it is buy a new one or find someone parting out and see if they have one in good condition..thats what i did and smooth sailing for me...o and another good way to tell if its bad would be roll up a newspaper and stick it in the fan and see if it stops really easy i say this because it looks like you fan isnt moving very quick may just b the videosigpic
93 325i 120k
mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
future mods: chip, m3 cams, headers, turbo
That sounds like a bad bearing. It could be the water pump, fan clutch, alternator, or timing belt tensioner. With the engine stone cold remove the alternator/water pump belt and see if the noise is still present (don't run the engine over a minute). If the noise goes away it is from the timing belt. Otherwise it is from the alternator, water pump or fan clutch.The car makes it possible, but the driver makes it happen.
Originally posted by e30construction View Postmine was making this noise as well..take the fan and fan clutch off and see if its makes any noise when you turn it by hand or if theres any play in the bolt..may just be a bad fan clutch..if it is buy a new one or find someone parting out and see if they have one in good condition..thats what i did and smooth sailing for me...o and another good way to tell if its bad would be roll up a newspaper and stick it in the fan and see if it stops really easy i say this because it looks like you fan isnt moving very quick may just b the video
Originally posted by Khaleeezy View Postlol newspaper?Originally posted by z31maniacI just hate everyone.
No need for discretion.
Originally posted by 87e30 View PostJust anything steady you can stick in there that isn't your hand... newspaper is good because it gives and doesn't brake the fan if indeed the fan does want to keep moving. Newspaper/magazine/paper works well. A stick could potentially be bad since it would have no give. It's pretty easy to tell if the fan is going to stop or not.
