Here:
Front right hub assembly with brakes
Front left hub assembly with brakes
E36 front H&R/bilstien
E30 new front strut mounts
Front Tie rods (E36)
Rear left trailing arm with brakes
Rear right trailing arm with brakes
535i Diff output flanges
Ordered:
Trailing arm bushings
12 new half shaft bolts for diff
2 new collar nuts
New rotors (brembo)
New pads (pagid)
Brake sensors
Rotor retaining screws
Anti rattle clips
Tie rod replacement hardware
E46 M3 rear shock mounts
SuperBlue Brake fluid
M3 offset bushings
Up in the air:
custom control arm bushing brackets
I guess i'll have to have the new TA bushings pressed into the TA. Same goes for the M3 offset bushings and custom bushing brackets. (lollipops)
The stance of the rear should not change since I am keeping my bilstien/H&R E30 stuff. I am slightly worried that ride height in the front may be different but hopefully it will look OK. If not what are the remedies?
By the way, are we sure E36 M3 rear suspension won't fit? Below are pics of H&R springs and Bilstien shocks for the E36 M3...they look identical to the E30 stuff:
